PASM Memory Access
I have a PSM routine running in one cog· I would like to use the results from another cog also running PSAM.
Specifically, I would like to access the JW_etimer output in a cog running PASM. I can access it in SPIN with a Longmove, how do I create the same access to the data from PASM?· As an extension How do I access global memory from PASM?
rs_jim
rs_jim
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
It can also be confusing to figure out how to compile such longs with the right address in them.
I recall trying a bunch of different ways of representing labels, which were different depending on whether
the address was in the CON, VAR, or DAT sections. I don't think the manual clearly specifically explains that,
and I often get stuck for a while when that comes up, trying to figure out how to access something in the Hub from a cog.
Sometimes what finally works is kind of contrived, involving CON, VAR, DAT, and PAR values, and also @ symbols,
so I WISH I had good examples of
all the ways for cogs to access different things in the hub with the RDxxxx and WRxxxx instructions.
I recall my last working try involved using the graphics.spin ONSCREEN_BUFFER as the address long value
for two cogs to communicate through, resulting in weird pixel activity visible at the bottom of the screen.
Due to the amount of time it took to find something that worked that day, I left it that way.
If the Hub RAM address is less than 512 then it is easily and directly addressed in the rdbyte/wrbyte instructions,
except it's not obvious what will be compiled into that small section of Hub RAM and if it is in danger of corruption.
long myvar
and lets say that I write that address into myvar[noparse][[/noparse]0]
when I read into my asm code
mov temp,par
rdlong local,temp 'if I then do a
rdlong myval,local
would I not be reading into myval the contents of the memory location stored at myvar[noparse][[/noparse]0]? My question is how to write The address of a variable from another cog into myval[noparse][[/noparse]0] I have two cogs operating independently of each other that need to share that value at the same time and it is created by a third cog.
rs_jim
Now, with #3 the question is how to handle multiple PASM instances.· You could have an array for each instance, but that would be a waste of storage and mean you'd have to sync up any elements which need to be the same across instances.· A better way would be to use the COGID for each instance as a secondary index.· This would still use extra storage since you'd need to reserve 8 entries.
The best way is to provide each instance with an index value - see my sprite driver for an example.· I embed the index value in the D register number of the first instruction (which is a JMP) just before invoking COGNEW.· This can then be extracted by the PASM code and used as needed.· It's safe because the value is copied to the COG before the next SPIN instruction is executed.
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
