photoresistor
sir,
where is the photoresistor in parallax professional devevolment board? Guide me.
what is 10k pot in pdb? is it potentiometer or else?
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
There is no photo-resistor on the PDB. That component is like a transistor or resistor as something you would plug into the breadboard if you wanted to connect it. The tw 10K pots are essentially variable resistors which can also be used a s adjustable voltage dividers. They are located on the far right side of the board. The two are side-by-side. The one above is used for LCD contrast while the one below is used for volume control for the on-board audio amplifier. Take care.
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
