We need a SIGNED 32x32 multiply and 32x32 divide for PropBASIC. Can you help ?
We need a signed multiply and divide routine for PropBASIC.
The input will be 32 bits, and the results will be 32 bits.
I looked in the object exchange, but I didn't see anything.
A search of the forum found some unsigned routines.
If you have a routine, or can whip one up, I would appreciate it.
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
Bean.
Yes it does...
input A, B;
Sign = 1;
if (A < 0) Sign = -Sign, A = -A
if (B < 0)·Sign = -Sign, B = -B
Perform unsigned multiply/divide into result R
if (Sign < 0) R = -R
I would recommend you look for a 32x32=64 multiply routine to start off. If you plan to include the PBASIC operators ** and */ on native longs, you will need it as a foundation. Since Spin includes **, you might find the routine you need in Chip's interpreter code.
This is lifted directly from the Spin interpreter, but with the interpreter control logic removed.· You need to declare LONGs or RES asm_x, asm_y, asm_n, t1, and t2; as written in the course of computation the original asm_y gets absolute valued, asm_n is trashed,·and the signed result of the signed multiply is written to the 64 bit pair t1:asm_x.
You can lift the code from my faster spin interpreter. IIRC I increased it's performance from some code Chip posted later. Link is in my signature under Tools.
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
