PropNIC + secure network... — Parallax Forums
VaatiVaati Posts: 712
edited 2009-09-09 09:44 in Propeller 1
I got ucontroller's propNIC, put it together with a·perfect soldering job, got the code and set it up for the demo board and loaded the propIRC program and....
It didn't work.
After a number of test changes, I came to the conclusion that it must be because our network is secure.· As I really don't want to spend money to set up another network just for the sake of getting a spin web browser to work, I was wondering whether any of you people know how to set it up so it works with a secure network.
Forest
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
  • Ken PetersonKen Peterson Posts: 806
    edited 2009-09-08 15:48
    What does 'secure' mean? Firewalled?
    ·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
    - Bjarne Stroustrup
  • VaatiVaati Posts: 712
    edited 2009-09-08 15:51
    Well, it requires a password to connect to the network...
    edited 2009-09-08 15:59
    See if it works direct to your PC, without the network.· Set your PC up to use a fixed IP and mask compatible with what you're using on the PropNIC software, connect the PC to the PropNIC with a straight through or crossover cable (your PC also certainly autodetects, so it doesn't matter which), and see if you can ping the PropNIC.
    The software I am using from Harrison doesn't do DHCP so you *must* supply it a fixed IP address; some networks do have trouble with this.· It is usually possible to configure the network routers to let traffic through to a simple device, but you may have to program a firewall or router to let traffic through to its IP or over the port you're using.
  • DynamoBenDynamoBen Posts: 366
    edited 2009-09-08 18:45
    Vaati said...
    A network can't be secured like this, however folder shares and PCs on a network can be secured in the way you are describing. For your testing I would suggest a crossover cable direct to your PC which was mentioned in the previous post. If that works and you move back to your corporate/home network and it doesn't work be sure your IT department isn't block port 80, which is the HTTP port.
  • Harrison.Harrison. Posts: 484
    edited 2009-09-08 20:42
    DynamoBen said...
    Vaati said...
    Vaati,
    Could you describe your network configuration in more detail? Do you have to authenticate when you try to access the internet (such as when you open your browser)?
    DynamoBen,
    Some corporate and school networks are setup to require authentication before you can access any network resources. This can be done with transparent proxies (if you only want to restrict web access) or with products like ISA Server. Some networks will go as far as quarantining your computer/device until you authenticate.
  • VIRANDVIRAND Posts: 656
    edited 2009-09-09 07:44
    Someone I know has to use a VPN client and type in a pseudorandomized timecode password from some kind of calculator-like device from RSA that changes every second just to get on their office network.
  • dMajodMajo Posts: 862
    Harrison. said...
    DynamoBen said...
    Vaati said...
    Vaati,
    DynamoBen,
    @DynamoBen (just an addition to Hassison)
    Many (almost all)·manageable layer2/3 switches have configurable authentication and will not let you in (through the phisical port - RJ45 connector) until you are not authenticated. This can be done in many ways (internal user/password list, on mac address basis, through a radius server ...)
    · Propeller Object Exchange (last Publications / Updates)
