How to put current clock ticks in a variable and add 15 seconds to it [SOLVED]
Good morning everybody,
I am trying to establish a cyclic reading of a sensor from an infinite loop. Basically, it's a polling sequence and I would like to read a sensor every 15 seconds or so. Timing doesnt need to be precise and I would like to avoid using a cog or any kind of bloated code. I currently have the clock object loaded, but I can't use PauseSec or pause1s, as I don't want to stop the loop from running.
I think the solution could be in reading the current propeller clock number of ticks into a variable and add 15 seconds worth of ticks. I have no idea how to do this nor how many ticks covers a 1 second period. Could someone help me, please.
Here's what I try to achieve, in pseudocode:
Many thanks for any assistance.
Cheers,
Alex
Post Edited (4Alex) : 9/8/2009 3:34:26 PM GMT
repeat 'check if time to read sensor if longVarDelayedClock > longVarCurrentClock 'read sensor here 'schedule next reading time in 15 seconds from now longVarDelayedClock := longVarCurrentClock + (15 seconds * no_of_ticks_per_sec) 'do other stuff here 'and then loop
Cheers,
Alex
make sure you do the compare by sub and compare with 0 otherwise you get problems when cnt wraps. Also only works to ~25 sec, cnt wraps at ~25sec
Thank you for your assistance. BTW, I use some of your objects: they are well written and very useful. Congrats.
@Ken:
I apologise if the solution was already in the manual. I didn't find it so I guess I was seeing only the one tree instead of the whole forest. I was studying the clock object and coulnd't figure out how to use the various clock commands. I tryied a few things and it turned ugly. I had to implement a variation of your code snippet (because my CON is already defined with _clkmode and _xinfreq) and it works perfectly. For future reference for someone else, here's my code:
Many thanks again for your help.
Cheers,
Alex
Post Edited (4Alex) : 9/8/2009 3:44:44 PM GMT
Cheers,
Alex
