How to etch borosilicate glass?
Phil Pilgrim (PhiPi)
Okay, this has got nothing to do with electronics (that I know of), but I'm desperate, and there are a lot of smart people in Parallaxforumland, so someone may know the answer.
What do you use to etch borosilicate glass?
All I want to do is produce a frosted design using an adhesive-backed vinyl stencil that I cut with my sign-cutting machine. The usual glass etching creams (containing ammonium/sodium bifuorides) from the art supply store won't touch this kind of glass. I watched a youtube video that demonstrated molten Drano (sodium hydroxide) reacting with glass. That's not only extreme but just plain scary. Would Drano dissolved in water work? Any other ideas? What should I add to create a paste that stays in place and won't run off? I've even tried a bake-on glaze, but it forms a skin as it dries that pulls up with the stencil.
This is for a birthday gift, and the clock is ticking.
Sorry, moderators, for being so OT. But this is the only forum I do. Did I mention I'm desperate?
Post Edited (Phil Pilgrim (PhiPi)) : 9/6/2009 6:12:53 AM GMT
Do you have access to a sand blaster? - I know this method works, but you might need to double up on the thickness of your stencil.
Beau Schwabe
IC Layout Engineer
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Tia'Shar Manetheren
I know it's not a perfect solution, but it's something to consider.
Let's call that the understatement of the century.
Hydroflouric acid will most certainly work, but get it on your skin without the correct survival kit and your chances of survival are pretty minimal. Nasty just does not do it justice [noparse]:)[/noparse]
We lost a guy a few years ago who was not adequately trained in contact treatment. It's not a nice way to go.
Check the Safety portion of this en.wikipedia.org/wiki/Hydrofluoric_acid
Having said that, it will do what you want standing on its head with one arm tied behind its back.
lt's not particularly silly, is it?
That's pretty much what I've done. I went back to the bake-on glaze and used Con-Tact paper as a mask. It has a less aggressive adhesive than the vinyl, and I can pull it off quickly before the glaze completely skins over. I also simplified the design significantly, so there'd be less touch-up to do, and removed from it all the little "islands" of masking that might not pull up cleanly (e.g. the little triangle in the letter "A"). Despite the glaze being brushed on and not self-leveling, the results came out pretty good. Once baked, the glaze is dishwasher-proof. 'Still not as good as etching or sandblasting, but adequate.
Thanks to all who contributed suggestions! Next time, I'll be sure to read the label to see what kind of glass I'm getting. The etching cream actually works great on non-borosilicate glass.
