It's not working.......
My SX isn't working....· I have no idea what it could be that is causing it not to work....
My setup is just a breadboarded SX chip with a 10k pull up resistor on the mclr, and have the sx powered with 3.3 volta, and have it connected to the sx blitz.
Any tips on troubleshooting or what my problem could be?
Forest
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
Forest
I know that 3V3 is "in range", but I'd stay with 5V for the present.· At any rate, verify it with a voltmeter.
Use the circuit depicted in the datasheet and double-check your wiring, then check it again.
You said you are using a bread board, so that suggests that you are using the DIP version of the SX28.
So make sure that you followed the correct pin out, DIP and SSOP versions are pinned out differently.
Section 2.1 page 6:
http://www.parallax.com/Portals/0/Downloads/docs/prod/datast/SX20AC-SX28AC-Data-v1.6.pdf
Chris Savage
Parallax Engineering
50 72 6F 6A 65 63 74 20 53 69 74 65
