TV Video Problems (Got Color!)
blittled
I set up the circuit for TV Video on a breadboard and everything works fine. Then for some reason the output goes to black and white only. I checked the connections with a voltmeter and it checks out. I finally resoldered the connections on a female header on a PSM board that I connect to the resistors to and the color came back. After awhile the screen goes black and white again and I can't get the color back. I think I still may have a bad connection. What resistor combo causes black and white only?
What electronics need - MORE POWER!!!!!!!
Post Edited (blittled) : 9/5/2009 2:45:01 PM GMT
Pretty sure it's the 270 ohm that adds the chroma signal in.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Touch the crystal and see if that makes the color come and go.
Check the chroma frequency in the program DAT; It should be 3579545 for NTSC American analog TV or something else for PAL.
For one inaccurate crystal maybe try adjusting for a single project's board by changing the crystal frequency in CON
or the chroma frequency in the tv object parm DAT sections in the program by a small amount from -3000 to 3000.
Edit:Also, crystal must be very close to the propeller chip and best soldered in. Long wires make the crystal inaccurate.
It might help a lot to put 10pF caps from crystal wires to ground, although I heard they are already inside the Propeller.
Do you have a bypass capacitor across and close to the Propeller power input?
Are all 4 VCC and VSS pins connected to the power?
Does your 3.3V power supply Voltage Regulator require a over 100uF capacitor that's missing across it's output?
The color comes from one pin through a resistor and it's very unlikely to have intermittent color from a wrong resistor.
Again, bad video connection or if you are experimenting with transmit antenna it's likely to have intermittent color.
(^Home made board troubleshooting ideas added)
Post Edited (VIRAND) : 9/4/2009 8:11:31 AM GMT
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
PS:· Are you saying that you have the same problem with the breadboarded Propeller?· Or, that it works with the breadboard but not with the PSM?
Female header soldered on the 10 pin header breakout. I then use a Parallax Breadboard RCA Connector. The resistors are 1K, 560, 270 10% tolerance 1/4 watt. The connection between the breadboard and PSM: Short 24 gauge wire from the RCA Connector ground and the ground on the 10 pin header. A servo 3 conductor cable with 3 pin headers to plug into the resistors on the breadboard and the female header.
Results:
Black and white screen. Pressing on the crystal does sometimes bring back the color. But then in about 3 minutes it loses color until pressed again. I tried resoldering the two pads on either side of the crystal and it only brings back the color for about 3 minutes.
Is this something that can be easily repaired with a 15 Watt Soldering Iron and a 30 Watt desoldering iron with a squeeze bulb? Thanks for all your advice.
Rayman: The PSM is definitely an awesome device and I'm very impressed you take the time to build and test every board. This may be a poor connection but I've learned from personal experience those are always the hardest to track down since they can work sometimes and sometimes not depending on the mood of the circuit [noparse]:)[/noparse]. Reminds me of when you take a car into the shop due to a noise and it doesn't make it for the mechanic. [noparse]:)[/noparse]
Post Edited (blittled) : 9/5/2009 2:46:03 PM GMT
On PAL I have noticed that the background colour beating can be minimised/masked by altering the frequency quoted in _xinfreq. On one of my bds the xtal was about 1.5KHz lower than the marked 5.000MHz. Obviously a small error could have been introduced by measuring it but when 4_998_500 was used the chroma was better. With regards to your problems, if I used numbers further away in either dirrection colour lock was lost.
Try some numbers and see what happens. The mass produced xtals are never exact, for better acuracy you pay more.
Style and grace : Nil point
Rayman: It's no big deal to have the crystal off a little. I was wondering though if it's easy to replace the crystal? Hmmm..... I got a couple 6.25MHz crystals lying around [noparse]:)[/noparse].
Sounds like you can solder though... If you PM your address, I'll mail you an new crystal.
Rayman: Thanks for the gracious offer. I don't think I need one now but if I do I have a couple of 5 MHz crystals so I'll use one of them if it happens again.
Thank all that helped and gave me suggestions during my "false" alarm. Don't let my ramblings discourage anyone from buying a PSM. It is a very useful platform to work from and Rayman does quality work. I would recommend one to anyone.
The crystal may not be off but I feel like I'm a little off [noparse]:)[/noparse]
1) Video of NTSC/PAL
2) Encode the chroma
It was this that led me to the Prop path. AVRs have no problems with the mono or RGB but req encoder chips, which are getting tricky to get now and would req the same acreage of PCB that the rest of the project.
So it is this is an ability of the Prop that has been so cleverly woven in, and it is not surpising that the frequencies have to be so finely set.
All this assumes that the Xtal on your Prop isn't "slightly wrong, one way" and the Xtal in the TV's decoder isn't "slightly wrong,the othe way"
