PropBASIC 00.00.04 Sept 1, 2009 Download it and try it. - Page 3 — Parallax Forums
13»
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-09-03 06:46
    There is a problem with long variablenames.
    If I change temp into tempVariable the compiler generates
                MOV     tempVariable,#1                          '  FOR tempVariable = 1 TO 20
    __FOR_tempVa
                AND     LED,INA WZ, NR                           '    LED = ~LED
        IF_NZ   ANDN    OUTA,LED
        IF_Z    OR      OUTA,LED
                MOV     __PARAM1,#500                            '    Delay 500
                CALL    #Delay
                ADD     tempVariable,#1                          '  NEXT
                CMPS    tempVariable,#20 WZ, WC
        IF_BE   JMP     #__FOR_tempVariable_1
    The label __FOR_tempva is truncated (should be __FOR_tempVariable_1).
    regards peter
  • JonnyMacJonnyMac Posts: 9,675
    edited 2009-09-07 21:48
    Bean has been [noparse][[/noparse]quietly] working on PropBASIC and I've been doing some testing for him -- we worked together on SX/B so it makes sense for us to continue that partnership on the initial cut of PropBASIC. Just to show you that a bit of progress has been made it a week, what follows is a real working program.
    Interesting notes:
    -- pins can be pre-initialized HIGH or LOW
    -- SEROUT works and allows variable pin usage; great if you have two devices on different pins at the same baud
    No surprise, this looks a lot like SX/B. We added XIN which is easier to use than FREQ.
    '   File...... serout_demo.pb
    '   Purpose... SEROUT demo using Propeller Demo Board
    '   Author....
    '   E-mail....
    '   Started...
    '   Updated...
    ' Device Settings
    DEVICE          P8X32A, XTAL1, PLL16X
    XIN             5_000_000
    ' I/O Pins
    TX              PIN     30  HIGH                ' output and high (idle)
    LED             PIN     16  LOW                 ' output and low
    ' Constants
    Baud            CON     "T115200"
    FirSt           CON     "A"
    Last            CON     "Z"
    ' Parallax Serial Terminal (PST) Constants
    HOME            CON     1
    BKSP            CON     8
    TAB             CON     9
    LF              CON     10
    CLREOL          CON     11
    CLRDN           CON     12
    CR              CON     13
    CLS             CON     16
    ' Variables
    alpha           VAR     Long
    ' Subroutine / Function Declarations
    TX_BYTE         SUB     2, 2                    ' shell for SEROUT
    DELAY_MS        SUB     1, 1                    ' shell for PAUSE
      PROGRAM Start
    Start:
      DELAY_MS 10                                   ' TX idle for 10ms
      TX_BYTE TX, CLS
    Main:
      DO
        FOR alpha = First TO Last
          TOGGLE LED
          TX_BYTE TX, alpha
          DELAY_MS 50
        NEXT
        TX_BYTE TX, CR
      LOOP
    ' Subroutine / Function Code
    ' Use: TX_BYTE txpin, byteout
    ' -- shell for SEROUT at fixed baud rate
    ' -- allows selection of TX pin for multiple devices (e.g., LCD & terminal)
    ' -- Baud (rate) is set as program constant
    SUB TX_BYTE
      SEROUT __param1, Baud, __param2
      ENDSUB
    ' Use: DELAY_MS milliseconds
    ' -- shell for PAUSE
    SUB DELAY_MS
      PAUSE __param1
      ENDSUB
  • BeanBean Posts: 8,129
    edited 2009-09-08 02:07
    We need to get a couple more commands implemented before we release this. Like SERIN, SHIFTIN, SHIFTOUT, etc.
    Lucky for us, Jon is working on some formal documentation too.
    I'm on a 10 day cruise starting on Thursday, so that will cut into development time.
    Keep the faith, it will be release as soon as we can.
    Anyone who has used SX/B will be VERY familiar with PropBASIC. Those that used PBASIC will have a slight learning curve.
    Bean.
    Does that byte of memory hold "A", 65, $41 or %01000001 ?
    Yes it does...
    edited 2009-09-08 02:58
    Bean: Did I hear 10 day cruise???
    Well that is 10 days & nights to do prop development without interruptions tongue.gif
    · Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
  • danieldaniel Posts: 231
    edited 2009-09-08 02:59
    HollyMinkowski said...
    I'd love to be able to write a tiny compiler for a controller.
    I need a good book about compiler creation.
    I would need a "Compiler Construction for Dummies" type of book, not a tome
    usable only by CompSci Phd's
    Jack Crenshaw's 15-part Let's Build a Compiler may provide be a usefully pragmatic point of view. I found it to be quite approachable.
    See it at compilers.iecc.com/crenshaw/..
    Do note that Bean may be using an entirely different approach in his PropBASIC.
    Daniel
    edited 2009-09-08 07:03
    Jon, Bean,
    Good progess.
    Are there plans to make BAUD variable, I mean to pass via PAR table.
    I know PAR can be used as a value, but on the basic level you could allow
    for PAR(i) where i denotes the i_th element of the long array passed to
    the compiled PASM code.
    For example, if the 2nd entry would be the baud parameter,
    we could use SEROUT pin,PAR(1),value
    That would allow us to use multiple instances of the same PASM code
    but with different parameters (like BAUD).
    regards peter
    edited 2009-09-08 14:06
    To get to variable baud rate one would have to pass the bit timing instead of the baud rate; this fine for many of us but I know from experience that even BASIC Stamp users incorrectly set the baudmode value incorrectly and have problems. Perhaps we can have a SEROUT2 that takes four parameters: pin, mode, bit_time, byte. That said, changing baud rates on the fly is fairly infrequent, don't you think?
    edited 2009-09-08 15:06
    Hi Jon,
    You misunderstood. I am not talking about changing baud on the fly.
    What I mean is to have the ability to pass several values (via PAR)
    when starting a cog with compiled pasm code.
    Rather than maintaining a lot of 'Uart' PropBasic drivers for multiple
    baudrates, maintain 1 such program that you can use for multiple
    cogs running multiple uarts. Besides baud one would also pass
    the pin.
    If bittiming would be required instead of simple 9600 for example,
    that could be handled bg the basic code.
    This is a universal approach making the compiled code much more
    versatile and also allows easy integration of PropBasic with Spin programs,
    for those that do not use PASM or want the entire propeller program
    in PropBasic.
    regards peter
    edited 2009-09-08 15:20
    What I suggest, Peter, is that when Bean releases a new version you give it a try. I'm not sure I understand your idea for implementation -- but then, I rarely do as you and I take very different approaches to programming. The compiler supports ASM...ENDASM so you could create a working model for Bean to work from; that's what I've been doing with ideas I've been throwing out. In fact, I'm "borrowing" some code from FullDuplexSerial.spin to see if I can write a routine called SEROUT2 that works as I suggested above.
  • RsadeikaRsadeika Posts: 3,882
    edited 2009-09-08 15:29
    I have a project where I am using FullDuplexSerial.spin too create ser[noparse][[/noparse]0], ser, and ser. They have different baud rates, as well as different pin set assignments. So, will propBASIC be able to accomplish the same thing, hopefully using a lot less cogs, then the spin object. And, what will be the estimated BAUD rate limit?
    Ray
    edited 2009-09-08 19:10
    Remember, PropBASIC is like SX/B in that it compiles keywords inline -- so SEROUT gets compiled in place to native assembly. Since PropBASIC supports ASM..ENDASM blocks you can add features as you like (or ask someone to code them for you).
    I "liberated" some code from FullDuplexSerial to create this subroutine that supports any pin, variable mode (T, N, OT, ON), and variable baud rate, though to get the variable baud rate you have to pass the bit time (this is easily accomplished by creating bit time constants for the baud rates you want to use). I have tested it up to 2_000_000 baud using PST. To go any faster you'd have to remove the variable mode (e.g., fix to True mode output) to cut down on the cycles required to transmit a bit.
    Again, this code is running inline and not buffered, so the program is blocked from doing other things while you're transmitting a byte (just like PBASIC and SX/B).
    ' Use: SEROUT2 txpin, mode, bittime, byteout
    ' - variable mode, variable baud
    SUB SEROUT2
      ASM
                            mov     __temp1, #1             ' pin# to mask
                            shl     __temp1, __param1
                            test    __param2, #%10  wz
                            test    __param2, #%01  wc
            if_z_ne_c       or      outa, __temp1
            if_z            or      dira, __temp1
                            or      __param4, #$100         ' add stop bit
                            shl     __param4, #2            ' add start bit
                            or      __param4, #1            ' force 1 idle bit
                            mov     __temp2, #11            ' bits to tx
                            mov     __temp3, __param3       ' get bit time
                            add     __temp3, cnt            ' sync with sys cnt
    :txbit2                 test    __param2, #%10  wz
            if_c_and_z      xor     __param4, #1
                            shr     __param4, #1    wc      ' get bit to TX
            if_z            muxc    outa, __temp1
            if_nz           muxnc   dira, __temp1
                            waitcnt __temp3, __param3       ' time bit, reload
                            djnz    __temp2, #:txbit2       ' update bit count
      ENDASM
      ENDSUB
  • VIRANDVIRAND Posts: 656
    edited 2009-09-09 08:17
    Just a little suggestion:
    Are there spare cogs to run a video terminal on the Propeller?
    Everything's nicer when it's not hooked up to a PC.
    Like a digital camera with it's own printer, or ye olde Polaroid, for example.
    edited 2009-09-09 12:40
    Virand,
    · PropBASIC will run in 1 cog.
    · You can create PropBASIC "objects" that run in different cogs. Hopefully we'll have time to create the standard objects: Keyboard, Mouse, TV, VGA, etc.
    · PropBASIC compiles on the PC. If you want to use the propeller itself for BASIC development you should look at femtobasic.
    Bean.
    Yes it does...
