Is propeller for me? — Parallax Forums
replica robreplica rob Posts: 9
edited 2009-09-04 01:30 in Propeller 1
Hi, I have no experience in micro controllers, and I am thinking of buying a micro controller programming kit.
The projects I work on deal with scale models and im trying to expand the realism of the models by adding light, sound and servo movement.
The main thing im looking for is the ability to program a chip so after it is installed in the scale model my customer can activate the sequences with a button. For instance they press a button and a servo opens the landing gear on a airplane while playing a wav file of a jet engine and running a light sequence that is specific to that aircraft.
Is this something that can be accomplished with the propeller?
I would appreciate any product suggestions as far as what I would need to learn the product as well as advice on what goes into assembling the device. What I mean is would I after writing the program simply connect the lights, speaker and servos to the pins on the micro controller or would I need to have a much deeper education on components such as resistors and so fourth?
Thanks in advance for any replies.
Rob
  • LeonLeon Posts: 7,620
    edited 2009-09-02 21:51
    Get a good book like The Art of Electronics by Horowitz and Hill.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • T ChapT Chap Posts: 4,249
    edited 2009-09-02 21:57
    All of those are very easy to do with the Propeller. There is an MP3 player (possibly was too) called a Vmusic2, servos are straightforward and easy to connect. Controlling LED's or lights is a simple task, none of these requiring any deep knowledge of electronics. You really just need to buy a development board and start experimenting.
    edited 2009-09-02 22:03
    Yes, the Propeller can do all of that. There's existing software to move a servo given a desired position. There's existing software to play a WAV file. There's no ready-made software for reading a button or doing a light sequence, but the BS2 Functions object in the Object Exchange has routines to make it easier.''
    You will need some kind of speaker amplifier. The Propeller Demo Board has a built-in headphone amplifier that will need an amplified speaker and some other Propeller boards have audio outputs that will feed a Line-In input of an amplifier.
    For the lights (LEDs?) you will need a current limiting resistor that depends on the color of the LED (mostly). A typical red LED would need 82 Ohms in series. A typical green LED might need 68 Ohms. It depends on the specific LED and how bright you want it. Learn Ohms' Law (search the Wikipedia for that).
    edited 2009-09-02 22:13
    replica rob said...
    Hi, I have no experience in micro controllers, and I am thinking of buying a micro controller programming kit....
    You also might want to take a look at the Basic Stamp, also made by Parallax. They have all sorts of beginner-level education kits and tutorials that take you step by step. In my humble opinion, the Propeller is not for someone with zero knowledge of microprocessors, but my idol, Mike Green, might disagree with me on that.
    good luck,
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-09-02 23:32
    Welcome to the forums, replica rob
    as the others have mentioned...
    there is a good microcontroller starter kit, using the basic stamp, called "What's a Microcontroller" - I like to recommend that as start-from-square-one book:
    http://www.parallax.com/Store/Education/KitsandBoards/tabid/182/CategoryID/67/List/0/catpageindex/2/Level/a/ProductID/327/Default.aspx?SortField=ProductName,ProductName
    That's from a group of other good starters, here:
    http://www.parallax.com/Store/Education/KitsandBoards/tabid/182/List/0/CategoryID/67/Level/a/Default.aspx?SortField=ProductName,ProductName
    tons of tutorials via here:
    http://www.parallax.com/Education/EducationHome/tabid/463/Default.aspx
    cheers,
    - Howard
    edited 2009-09-03 01:03
    The basic stamp sounds like it might be a fit for you.
    If you go the propeller route then each project will cost you less
    but it will be a bit harder to do. But remember that the people here
    on this forum will help you over any hurdles.
    We have The Art of Electronics by Horowitz and Hill at work and it is a huge
    and very expensive book. I recommend something more like "Electronics for Dummies"
    - Some mornings I wake up cranky.....but usually I just let him sleep -
  • replica robreplica rob Posts: 9
    edited 2009-09-03 01:22
    Thanks for all the replies.
    With the propeller, if I wrote a program that activated a bank of leds in sequence like an array, at the same time played a wav and at the same time moved a servo half a turn, would I need to connect a servo driver, amplifier and proper resistors for the leds?
    edited 2009-09-03 01:36
    Also which kit would I purchase that will allow me to learn, and also serve as a programmer for production of the finished chips
    I noticed there are lots of different options.
    edited 2009-09-03 02:07
    The PE labs kit allows you to program using the PropPlug that is included. It also includes resistors, LEDs, a Propeller, and a learning guide. For the di hard beginner I would suggest "Robotics with the BoeBot". More expensive, but easy to use. It also covers the use of servos and IO very well.
    Computers are microcontrolled.
    Robots are microcontrolled.
    I am microcontrolled.
    But you·can·call me micro.
    If it's not Parallax then don't even bother.
    I have changed my avatar so that I will no longer be confused with others who use generic avatars (and I'm more of a Prop head then a BS2 nut, anyway)
    edited 2009-09-03 03:54
    With pretty much any microcontroller, you'd need resistors for the LEDs. Servos use logic level inputs that can be driven directly by most microcontrollers. It's generally a good idea to use a 1K resistor between the Propeller (or other microcontroller) and the servo's control lead. This reduces the likelihood of noise from the motor feeding back through the control line to the microcontroller. It's not necessary, but I'd recommend it. You will need some filtering for the I/O pin(s) used for audio output. Look at the schematic for the Demo Board for an example. You could also look at the application note on the cog counters (AN001) which is downloadable from the Propeller download page. That explains how the digital to analog conversion mechanism works and gives a sample schematic.
    edited 2009-09-03 04:23
    Hello Rob,
    if you have no knowledge about electronics I highly recommend to learn some basic things like:
    - Ohm's Law
    -where current-limiting resistors are needed,
    - in which cases you need a transistor to switch on/off lamps/LEDs or DC-motors
    if you want to do all those things mentioned in parallel at the same time the propeller is better suited
    without this basic knowledge it will be hard to narrow down faults
    best regards
    Stefan
    edited 2009-09-03 04:45
    Rob,
    Yes, you would need support circuits. Typically, these things are not directly driven by the chip.
    I recommend the Propeller Education Kit, and the 40 PIN DIP version, if you can get it. The 40 pin DIP is the most friendly package to work with, IMHO. Several members here also sell some really cool kits that are structured so you can build lego style, if you want to. A look at those, after you've done some labs and know your way around would be a good idea.
    There are four core elements to this:
    1. Scope of understanding for your various project plans. LED, SERVO, SOUND, etc...
    It's totally possible to zero in on one of these, say the LED, and get some success. I would do that, then tackle another one, potentially building a model with that effect.
    2. Programming
    The Propeller isn't that tough for the stuff you are wanting to do. There are lots of objects, and you can do the same lego style approach. Timing loops to flash LED's, Move the servo, user input, etc... Again, tackle one at a time, get some success then build on it. The Prop is really great for this.
    3. Gear
    If I were you, focusing on the programming and some very simple labs will get you doing some fun stuff! The LEDs, for example are not tough, nor are simple sounds and other things you can do with the PE kit labs. Those circuits are not complex, and the rules for the electronics can be understood at a level where you can troubleshoot visually. Moving beyond that means you need some stuff! Multi-Meter, Logic Probe, O-scope, etc... The Multi-Meter is the most important starter device. You can actually build your own propeller based logic probe, and an o-scope is the all purpose device to get when you can.
    For the kinds of things you want to do, it sure seems to me like modest, but capable, maybe used gear makes great sense. Ask around. There are lots of people here (who know this way better than I do), who can give you some good advice and help you with device selection and deals to be had. Totally go down this road, once you hit your "no gear" brick wall.
    Get a nice soldering station when you can. I'm on the pencil iron right now, and I'm reaching a point where I totally am going to upgrade. You can start solderless though. Breadboards and nice connecting wire can get you a long way. That's the PE kit.
    4. Electronics
    This happens in tandem with the Programming. Each task will open up the area of study, and when you do things in combination, or make your own board, then you start firing on all cylinders! There are lots of basic theory books where you can get your core, foundation skills established. Component types, DC theory, AC theory, Ohm's LAW, etc...
    This is where I'm learning a lot right now, BTW. It's as fun as the programming is. I would deffo look at ways you can source replacement components though. Once you start digging in, you are gonna need stuff to work with, and replace as you let the smoke out. (this will make perfect sense in the near future, trust me [noparse]:)[/noparse] ) Here in PDX, we've got one of those surplus stores with just a ton of stuff out on display. You go snoop around, bag up your goodies, pay at the door and go home and tinker. It's not expensive that way. Others here can tell you where deals are to be had.
    Thought you might appreciate a lay of the land, scope of effort wise. Most of what I just detailed applies no matter what micro you use. One distinguishing characteristic of the Propeller is it being hobby person friendly. You can get going with very small amounts of understanding, and components. It tolerates a fair amount too.
    Good luck and have fun!
    Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
    edited 2009-09-03 05:19
    replica rob said...
    If you want to play audio wav, the Basic Stamp 2, the Basic Stamp and the SX chip WILL NOT WORK FOR YOU.
    (not without some external chip)
    IF you want to play audio wav files easily, the Propeller Chip is the BEST way for you to go.
    (objects in the OBEX already exist for you to play wav files back directly from the prop.)
    As a prior BS2 and SX user and programmer, the PROPELLER language is just as easy to learn. IMHO
    edited 2009-09-03 20:04
    I ordered the 40 pin education kit and a spare chip, from frys, any thing else I should order to get started?
    edited 2009-09-03 20:15
    @Clock Loop
    Excellent point!
    That's correct the prop will be needed if he wants audio files to play.
    You likely saved him some grief.
    @replica rob
    You need parts, lots and lots of parts.
    See my post in the sandbox titled Holly's cheap parts roundup.
    You can get a lot of parts to tinker with from tossed out
    things like broken radios, tv's, vcr's..etc. and you can learn
    how to solder by taking parts out and soldering them back into the
    old junk circuit boards. It is interesting to see what you can make
    from the parts of a junked item.
    edited 2009-09-03 20:28
    Thanks. We have a few stores near here that sell parts like frys. Im reading tutorials and labs now to try and get a better understanding. At least now I know spin is a language and not a reference to the magazine.
  • hover1hover1 Posts: 1,929
    edited 2009-09-03 20:34
    I love the Propeller, but the BS2 might be the right fit here. Easier to learn for first time user.
    I have used the VMUSIC2 module to interface to BS1 and BS2 projects. It plays· .mp3 and .wmv files with simple serial interface. It's available for about $40.00 from Digikey,·Mouser, Dontronics, and others. Just put the files on a UBS Thumb drive and plug it in.
    Details here:
    http://www.vinculum.com/prd_vmusic1.html
    Some BS1 and BS2 examples here:
    http://www.scary-terry.com/vm2/vm2.htm
    Hope that helps,
    Jim
    Clock Loop said...
    edited 2009-09-03 20:43
    If you can get a few more dip propellers it would be a good idea.
    They will not be available from Parallax again for some time.
    edited 2009-09-03 20:55
    I noticed the other propellers were in stock, If I wrote a program on the 40 pin and the inventory was only in the other propellers would I need to reconfigure the program to use them instead?
    edited 2009-09-03 21:35
    RR - they're all the same from the software perspective. - H
    edited 2009-09-03 21:41
    You would be OK. Xtal and Supply voltages are all the same. Pin assigments are different from the DIP to LQFP and QFN. See:
    http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropellerDatasheet-v1.2.pdf
    replica rob said...
    edited 2009-09-03 21:47
    understood.
    I am really excited to get started. I am also glad there are so many people here who are willing to share.
    I have so many ideas running through my head, ill take it slow and do the prerequisite learning that all of you did and try not to ask noob questions that are covered in the book.
    edited 2009-09-03 22:54
    RR- yes, many if not most folks here are very helpful ... don't be too concerned about asking NOOB questions because we've all been NOOBs too... if it's something in the manual, I'd try to answer anyway - and then politely mention that you should read the manual [noparse]:)[/noparse])
    I've noticed that even after reading these things several times, trying it a few times - I still can't quite 'get it' ... that's were you need a second and third (and hundredth?) person to look over your shoulder. It's always best, when you have a coding problem, a bug, or whatever, that you post the code when asking for assistance - there is a code button (the ' # ") in the post / post reply / or edit menu. This helps us not have to guess or ask you more questions - and you'll get an answer faster. (In fact, how fast you get a good, solid reply may surprise you!)
    cheers
    - Howard
    (Emerging from Prop NOOBiedom - with a lot of help from here [noparse]:)[/noparse]
    edited 2009-09-03 22:59
    Leon said...
    Leon is correct in the type of book to get as a reference however, The Art of Electronics book is in the process of being updated. It still has lots of great info but it's a little out of date. I've been waiting for the third edition for about 5 years. turn.gif It's also pricey for an outdated book. Buy new: $110.00 $75.07
    From the WIKI
    Third Edition
    The 2nd edition is in many respects out of date, referencing obsolete electrical parts and omitting technologies developed since it was written. Because of this, the third edition is widely anticipated, leading to perennial rumors of its impending release. In 2006 the third edition appeared in some online databases with ISBN 0521809266, prompting further speculation. However, Winfield Hill responded with a statement that the book's arrival was still years off. Further excitement arose in January 2009 when the Borders bookstore began accepting pre-orders for delivery at the end of February.(1) This is an error; the manuscript is still not complete.(4]) The authors now anticipate publication in 2010
    I like this book as an affordable reference that's fairly current [noparse]:([/noparse]of course there are others available as well)
    Practical Electronics for Inventors (Paperback) by Paul Scherz
    2 new from $39.95 16 used from $17.99
    Post Edited (Bob Lawrence (VE1RLL)) : 9/3/2009 11:08:12 PM GMT
    edited 2009-09-03 23:30
    > The Art. of E. -·authors now anticipate [noparse][[/noparse]3rd ed.]·publication in 2010
    AA AAA· AAARRRGGGGG !
    Or you can look for books by Forrest Mims. Pretty inexpensive. I cut my teeth on those books back in the 70's. He has about 60 books out now. You can find them used all the time for about $5.00. Garage sale for $1.00
    Jim
