Most expensive Propeller addon yet..
Oldbitcollector (Jeff)
After my refurbished acer notebook wouldn't do VGA output at UPENE, I figured it was time
to do some notebook shopping. I needed something that was small (and cool enough) to
allow Propeller programing from my easy chair to help the spouse keep reign on the kids.
(Hard to abandon her to the shop and leave her with 2 1/2 teenagers to manage.)
This has got to be the most I've spent to date on a single Propeller Accessory. [noparse]:)[/noparse]
www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4424398&CatId=3987
Initial review is that it is certainly powerful enough to do everything I want to do with the Prop, but
the tiny keyboard wil take a little getting used to.
OBC
New to the Propeller?
Post Edited (Oldbitcollector) : 9/22/2009 1:57:25 PM GMT
OBC
This is the other half of my easy-chair Propeller setup.
http://forums.parallax.com/showthread.php?p=835481
I'm still working out the composite screen. (maybe video glasses?)
The only issue is that anything with breadboard isn't going to be airplane
friendly (wires which imply a bomb.)
OBC
I think you are going to love it. It is so handy to have something that you can take with you.
@Ken,
Are you talking about something like Bean's Prop Board?
Whit+
http://www.fatwallet.com/forums/hot-deals/944458?highlight_key=y&keyword1=asus+eee
If you get 7" lcd screen, 40w AC/DC adapter, Intel Cpu, case, keyboard, trackpad, etc, you must wonder how in the world do they make money when Kinkos charges me $50 to photocopy a color manual?
I didn't get a netbook but I found a cute new top and a 52 piece makeup kit
and they were almost giving the stuff away!
Great links to bargains on that fatwallet site!
- Some mornings I wake up cranky.....but usually I just let him sleep -
Yes, but I tried the 7" version before I bought this. I have to have the 10" inch screen. [noparse]:)[/noparse]
OBC
Don't confuse with the cheaper mini 10v (no high res screen)
Hmmm, maybe I'll send you two the details for your input since your desires are exactly my target market.
Andrew Williams
WBA Consulting
How about an opaque version of the carying case?· I picked this up at Hobby Lobby for $12 ... It measures 10"x16"x4" ... you can even put a nice 1/4" lock on either side of the handle.
Beau Schwabe
IC Layout Engineer
With the judicious application of some fine green wire and a steady hand you can easily add a jumper on the USB proto board to power it from USB and allow development on the road with only a laptop and a propeller. It's not _entirely_ compliant with the USB spec, but provided you don't turn on the servo switch you are pretty right.
lt's not particularly silly, is it?
Put a Propeller and simple video capture on a PCMCIA card. Let the video capture do simple VGA (640x480) and NTSC / PAL. Also on that PCMCIA card, put an EEPROM and a serial chip recognized by windows like the Prop Plug is. Finally, expose the Propeller pins with an end connector, and switchable buffer chip to cut down on "mistakes" static, etc... Sound seems a no brainer at this point, but I could be wrong.
The net result would be a Propeller that can be inserted into a laptop, provide serial and video outputs, and be connected to project breadboards with a simple ribbon connector cable.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
It's a shame he didn't sell more of these, as I don't think he's making them anymore.
The only drawback with these is the little breadboard would make people nervous on
an airplane. I'd love to see a "version 2" of this with SD, composite out, keyboard,
and USB connection.
OBC
@potatohead: Made the next purchase.. A usb capture device for composite video
and audio from Ebay. $9.00 (shipping included from China) This "should" complete
my go anywhere propeller setup.
OBC
I'm betting you'll find something else you can't live without. I know that I always do...
Whit+
www.moultriefeeders.com/productdetail.aspx?id=mfh-vwr
www.walmart.com/catalog/product.do?product_id=6023332
The first picture doesn't do the screen justice. I used my week-old Canon T1i 15MP, so it picked up the texture of the screen itself in the picture.
Andrew Williams
WBA Consulting
Post Edited (WBA Consulting) : 9/7/2009 2:10:01 AM GMT
I remember you eying mine at Wooster micro gathering. Hope your happy with yours.
Roger
Sellout has a slightly better one for $20 more.
Rich H
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
Post Edited (W9GFO) : 9/7/2009 5:12:31 AM GMT
using uController's Spinstudio Stacker again. Adding one of Bean's battery packs to the underside
makes it a near perfect portable development platform.
My current active portable development setup is:
* Netbook (I can get two hours out of the batteries)
* USB composite video/audio capture (on it's way)
* Either my PE-style kit box (demoboard), or the Game Stacker module. (Using Bean's 5cell battery holder)
I've been able to run the demoboard with video out for HOURS without having to change the batteries.
As soon as I switch to a fresh set, I'll start keeping track of the battery usage.
@Ken, I'd say for "airplane" friendliness, the "stacker" is pretty close. Just need to find a small (clear?) box for it.
(The last thing you want on an international flight is to create a panic with a breadboard & wires.)
(Naturally, it would be some silly American on board who would cause the panic.)
2009 has been the year of getting out of the basement lab. I'm pretty pleased with the results.
OBC
Post Edited (Oldbitcollector) : 9/8/2009 3:55:25 PM GMT
I think the 2 hours is a bit low for your new Netbook. I thought that one of the big selling points was the battery time, low power.
I get 5 hours on my VAIO T350P, which is quite a bit older, had hard drive, and DVD burner. You might want to check with the manufacturer to see if that is normal...it doesn't sound like it.
Doug
OBC
- Rick
I love this! (and I can soooo relate!)
OBC
When just programming video related things, it's really easy to just mount propeller, batteries or AC adapter and capture device together in small box. Add packing to keep things sane. Then just open it, turn it on, connect two USB cables to computer, and go. One for video capture, the other for prop programming.
This can be running in minutes, and is the sweetest deal I've done yet.
Just waiting for a package from Hong Kong..
OBC
so that I can have a single cable from the PC to the "prop-box" for both the video and
programming plug. I was also thinking that one of those $2.00 USB soundcards might be
an interesting way to capture the audio from the Propeller and pass it along the same
connection.
OBC
The software that comes with it won't work at netbook resolution, but VLC does
fine after the driver is loaded. I suspect my colors are a little off, as the lines
in the graphics demo are red instead of blue.
Here's a snapshot.
OBC
Post Edited (Oldbitcollector) : 9/21/2009 6:20:52 PM GMT
Looks like you ended up with a full resolution one.
Regarding netbooks and battery life.... that was one of my issues, and after trying the ASUS 7 inch, and 9 inch units, I am now happy with their 10 inch EEPC that caims 9.5 hours on a charge, and actually delivers close to that.
Very impressed. Connects anywhere at n speed, and built-in bluetooth for my wireless mouse to boot. Love it!
Cheers,
Peter, (pjv)
