signal processing on propeller , need help on assembly routines
hello all,
i am a beginer in propeller ASM and I am trying to do something like a downsampling routine. My code has one COG sampling and filling hub ram with 12 bits samples at 72 Khz. A second cog is reading the samples and I need a basic averaging to produce one sample over 6.
with RDWORD i retrieve samples but... I do not know how I can write 6 values in an array stored in cog ram, then perform a loop to do some math on it.
I've been trough deSilva tutorials around assembly but his example ex07c with ADDS sum, 0-0 looks a bit tricky...
Mainly my question is : how can I store and access local arrays in COG Ram ? In fact I need indirect addressing...
thanks a lot
Sylvain Azarian
thanks a lot
Sylvain Azarian
looking forward to have next' gen propeller with embedded multiply ...
welcome to the Forums!
SRLM> modified code with 0-0
At the risk of thread drift - that token is as old as dirt ... anyone know where it came from --- IBM BAL 360 or earlier even?
- Howard
Welcome to the forums. The suggestions to use self-modifying code are good ones, but I wonder if that's necessary. If you are simply trying to average samples and get a single result why not do that in the same cog that is acquiring the data? Maybe you have something else going on that you didn't mention. I'm doing that very thing and I can give you a PASM example if you would like it.
I've used self-modifying code but found it hard to get my head around. I try to use the simplest possible solution for my problems and I think averaging (or at the very least summing) in the acquisition cog would be simpler and less HUB intensive than writing all the values to HUB to be averaged by another cog.
Let me know if you'd like an example. I'm collecting 24-bit samples at 80Khz and averaging down to 10Khz or all the way down to 625sps. The 32-bit size of a long allows that without overflow. Doing it for 12-bits gives you lots of room for summing!
Peter
This is one of those areas where previous 8 bit experience used indexed registers to accomplish the task... it requires a change in mindset for the Prop.
' Build cursor pixels mov par,#32 'ready for 32 cursor segments movd :pix_l,#cpix_l movd :pix_r,#cpix_r :pixloop rdlong cseg_l,cshape_l 'custom add cshape_l,#4 rdlong cseg_r,cshape_r add cshape_r,#4 :pix_l mov cpix_l,cseg_l 'save segment into pixels add :pix_l,d0 :pix_r mov cpix_r,cseg_r 'save segment into pixels add :pix_r,d0 djnz par,#:pixloop 'another segment? ' Data d0s0 long 1 << 9 + 1 'd and s field increments d0 long 1 << 9 'd field increment d1 long 2 << 9 'd field double increment▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
About the advice to do that in sampling cog, in fact i need the datas in two flavors and the averaging is in fact a decimation filter that runs in its own cog.
I have :
- one task sampling at full speed ( 2 channels at 75 ksamples/sec @ 12 bits ) two analog channels and storing data in a HUB ram block "A"
- a second task, doing exactly the same and filling a second "B" block, once "A" is full.
- while B is being filled, a task reads the samples and decimate them ( low pass filtering ) and the result are stored in "C" buffer in a fixed radix format ( Q1.15 )
- same when A is being filled and B is full.
- another task doing a slow average and some data processing on "A" & "B" blocks for adjusting gain of the A/D converters ( that is why i need the averaging to be done elsewhere )
- another task managing display
- last task does a hilbert transformation on C buffers... and sends the output to a D/A converter
currently my main problem is being able to understand the addressing subtilities of the propeller assembly fixed point multiplication
thanks all for your advices, I hope my project will be published soon ... it aims to be a "Propeller defined radio". But "do not sell the bear skin before you killed it" ( poor translation from french). The road is still long before I can hear first "noise" from the receiver
sylvain
/* Digital filter designed by mkfilter/mkshape/gencode A.J. Fisher Command line: /www/usr/fisher/helpers/mkfilter -Bu -Lp -o 6 -a 1.6666666667e-01 0.0000000000e+00 -l */ #define NZEROS 6 #define NPOLES 6 #define GAIN 2.319917755e+02 static float xv[noparse][[/noparse]NZEROS+1], yv[noparse][[/noparse]NPOLES+1]; static void filterloop() { for (;;) { xv[noparse][[/noparse]0] = xv; xv = xv; xv = xv; xv = xv; xv = xv; xv = xv[noparse][[/noparse]6]; xv[noparse][[/noparse]6] = next input value / GAIN; yv[noparse][[/noparse]0] = yv; yv = yv; yv = yv; yv = yv; yv = yv; yv = yv[noparse][[/noparse]6]; yv[noparse][[/noparse]6] = (xv[noparse][[/noparse]0] + xv[noparse][[/noparse]6]) + 6 * (xv + xv) + 15 * (xv + xv) + 20 * xv + ( -0.0135636846 * yv[noparse][[/noparse]0]) + ( 0.1354403429 * yv) + ( -0.5962625798 * yv) + ( 1.4692829541 * yv) + ( -2.2523796180 * yv) + ( 1.9816107366 * yv); next output value = yv[noparse][[/noparse]6]; } }sylvain
I also wonder why you propose having multiple buffers. The filter cog is a consumer/producer. It should be able to wait on a lock to get the next sample, process the sample, then write out the output value and kick the lock so the next stage can handle it. No buffers required. Buffers are only required if the processing performed by the stage varies enough so some samples require more time to process than others, but the overall average is less than the sample interval.
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
thanks for your advices regarding multiplying. I agree with you that it is gone to be tricky...
About multiple buffering : the ADC are AD7823 from analog devices, with a serial clock and a "s/h" pin. I need a quite precise timing and currently the sampling cog is more or less doing nothing but sampling and wrlong at the end of the cycle. Not much space left for extra computing or queue management currently.
Each sampling cog ( 2 ) is filling 1024 words of data to make sure nothing is lost, the acquisition process is done at around 72000 samples / secs, on two AD7823.
I use a "flip/flop" with 1 semaphore for cog synchro : cog 1 makes filter while cog 2 is acquiring then change , cog 1 is acquiring and cog 2 is filtering and so on...
re-edit :
to produce "earable" sound on this software defined radio system, the dsp chain is quite complex. My idea is to use several cogs to split math operations and then be able to do the all of it.
for the reader who wants to know what is "softare defined radio" ( aka "SDR") google "Software defined radio for the masses", very good Pdf article from QST magazine
sylvain
Post Edited (sylvain.azarian) : 9/2/2009 7:18:30 PM GMT
