None of the programs on the HYDRA CD work.... -SOLVED-
None of the .exe files (excluding the games, mappy, and tile studio) work...· I was really looking forward to using bmp2spin...· I have tried it on my laptop, which has windows 2k SP2 and another laptop with windows XP.· Not one of the .exe files in the sources folder work...· Is there something that I need to do in order to run them??
Thanks.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
Post Edited (Vaati) : 9/1/2009 7:23:21 PM GMT
Thanks.
If instead you're getting an error popup, you need to make sure you have .NET installed.
Thanks.
Navigation commands:
CD [noparse][[/noparse]folder name]
DIR
[noparse][[/noparse]Drive]
Thanks.
Thanks for the help!
