PropBASIC 00.00.04 Sept 1, 2009 Download it and try it. - Page 2 — Parallax Forums
2
  • JonnyMacJonnyMac Posts: 9,347
    edited 2009-09-01 14:07
    humanoido said...
    Has anyone actually tried running this? Did it work?
    Yes. I was able to setup EditPlus so that I can edit the PropBASIC source files and compile them with a button press.
    edited 2009-09-01 14:09
    Rsadeika said...
    Are you typing in the full path, and the file name? For instance: PropBASIC F:\PropBASIC\test1.bas /p. I made an
    assumption that all you need is PropBASIC test1.bas /p, but that did not work.
    <edit
    The program, I think, is supposed to flash the LED, but with a setting of 'delay 500', I did not see anything happen.
    When I increased the value to 'delay 1500', then I saw it flash. So, I am not sure as to how the delay values
    are supposed to work.
    edit>
    Ray
    Version 0.00.03 has a small bug with values less than 512; it uses the immediate value but leaves out the required #. For values 512 and higher the compiler creates a symbol with the correct value.
    edited 2009-09-01 14:15
    Bean,
    With 0.00.03 if you have two or more PAUSE statements in the program you get a nasty error:
    Compile
    <snip>
    71 PAUSE 1024
    ERROR 2 DUPLICATE VARIABLE NAME "_1mSec" ; PAUSE 1024
    Exception EAccessViolation in module PropBasic.exe at 0001197C.
    Access violation at address 0041197C in module 'PropBasic.exe'. Read of address 0000008C.
    Output completed (3 sec consumed) - Normal Termination
  • BeanBean Posts: 8,129
    edited 2009-09-01 15:22
    Jon,
    Okay I fixed the problem with 9-bit constants as parameters, and the DUPLICATE VARIABLE NAME. Version 0.0.04 is in the first post.
    humanoido,
    I'm not sure, you need to have all the files in one directory. And the path/filename must be complete and be in quotes. I'd make it something simple like C:\PropBasic, then you would use:
    PropBASIC "C:\PropBASIC\test.bas"
    from the C:\PropBASIC directory.
    Bean.
    Does that byte of memory hold "A", 65, $41 or %01000001 ?
    Yes it does...
    edited 2009-09-01 15:24
    Peter Verkaik said...
    Bean said...
    · I've decided that the __PARAMx variables will be used exclusively for subroutine parameters. So you DON'T need to store them into other variables in the subroutine, because they will never be used by PropBASIC commands.
    That makes sense to keep overhead low. Can I assume the __TEMPx variables are reused whenever possible?
    Is there still a need for __PARAMCNT since all arguments to·a sub are 32bit values anyway?
    regards peter
    Peter,
    · Yes, the __TEMPx variables will be used for certain commands that need temporary variables.
    __PARAMCNT is still needed because subroutines can still have a variable number of parameters.
    Bean.
    Yes it does...
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-09-01 16:30
    Humanoido,
    I have put the compile command in a .bat file
    so you can compile by doubleclicking test.bat using windows explorer.
    You may need to edit the path.
    regards peter
  • RsadeikaRsadeika Posts: 3,847
    edited 2009-09-01 18:17
    I noticed that you have to have the DEVICE, and FREQ call out in the program. What if I
    want to run the program using the prop internal clock, will their be a provision for that?
    Ray
    edited 2009-09-01 18:55
    You probably need to set FREQ to the frequency of the internal clock.
    I would prefer passing the FREQ value via the commandline and
    that the generated spinfile would get a constant FREQ = <value_from_commandline>
    That way you don't have to edit the propbasic source just to run on another frequency.
    (I don't see the necessity for DEVICE at all for compiling code that runs entirely in 1 cog)
    regards peter
    edited 2009-09-01 20:02
    Rsadeika said...
    Ray
    Remember, we're on the very front end of things so there are a lot of rough edges. You can use RC mode like this:
    DEVICE          P8X32A, RCFAST
    FREQ            12_000_000
    After opening the Spin file in the IDE you need to comment-out the _XINFREQ line. A compiler update will take care of this later.
    Post Edited (JonnyMac) : 9/1/2009 8:10:18 PM GMT
    edited 2009-09-01 21:08
    I was pleased to notice that ASM/ENDASM works.
    I tried to implement indexed variables and came up with this
    DEVICE P8X32A, XTAL1, PLL16X
    FREQ 80_000_000
    LED PIN 16
    temp2 VAR LONG(3)
    temp var long
    Delay SUB 1
    PROGRAM Start
    Start:
      LOW LED
      FOR temp = 1 TO 20
        LED = ~LED
        Delay 500
      NEXT
      'temp2(2) = temp
    asm
                movd    __load,#temp2+2
    __load      mov     00_00,temp
    endasm
      FOR temp = 0 TO 2
        'temp2(temp) = temp<<3
        __PARAM1 = temp << 3
    asm
                mov     __temp1,#temp2
                add     __temp1,temp
                movd    __load2,__temp1
    __load2     mov     00_00,__PARAM1
    endasm
      NEXT
      Delay 5000
      GOTO Start
    END
    SUB Delay
      PAUSE __PARAM1
    ENDSUB
    It compiles, only temp2 compiles into
    temp2 res 1
    where it should be
    temp2 res 3
    And I wonder, is there a way to use less than 4 instructions to have temp2(index) = value
    regards peter
    edited 2009-09-01 22:24
    Don't you need a NOP before the MOV 0-0 instructions?
    edited 2009-09-01 22:45
    I don't know.
    What purpose could a NOP have? Delay?
    regards peter
    edited 2009-09-01 23:14
    I added some hubram read/write subs to the test file.
    FREQ 80_000_000
    LED PIN 16
    temp2 VAR LONG(3)
    temp var long
    Delay SUB 1
    Rd_Byte FUNC 1,2
    Rd_Word FUNC 1,2
    Rd_Long FUNC 1,2
    Wr_Byte SUB 3
    Wr_Word SUB 3
    Wr_Long SUB 3
    PROGRAM Start
    Start:
      temp = PAR
      temp = Rd_Byte PAR,3
      temp = Rd_Word PAR,3
      'inline
    asm
      mov __temp1,#3
      shl __temp1,#1
      add __temp1,PAR
      rdword temp,__temp1
    endasm
      temp = Rd_Long PAR,3
      Wr_Byte PAR,3,temp
      Wr_Word PAR,3,temp
      Wr_Long PAR,3,temp
      LOW LED
      FOR temp = 1 TO 20
        LED = ~LED
        Delay 500
      NEXT
      'temp2(2) = temp
    asm
    endasm
      FOR temp = 0 TO 2
    asm
                mov     __temp1,#temp2
                add     __temp1,temp
    endasm
      NEXT
      Delay 5000
      GOTO Start
    END
    SUB Delay
      PAUSE __PARAM1
    ENDSUB
    FUNC Rd_Byte '__PARAM1 is base, __PARAM2 is byteindex
      __PARAM2 = __PARAM2 + __PARAM1
    asm
      RDBYTE __PARAM1,__PARAM2
    endasm
      RETURN
    ENDFUNC
    FUNC Rd_Word '__PARAM1 is base, __PARAM2 is wordindex
      __PARAM2 = __PARAM2 << 1
    asm
      RDWORD __PARAM1,__PARAM2
    endasm
      RETURN
    ENDFUNC
    FUNC Rd_Long '__PARAM1 is base, __PARAM2 is longindex
      __PARAM2 = __PARAM2 << 2
    asm
      RDLONG __PARAM1,__PARAM2
    endasm
      RETURN
    ENDFUNC
    SUB Wr_Byte '__PARAM1 is base, __PARAM2 is byteindex, __PARAM3 is value
    asm
      WRBYTE __PARAM2,__PARAM3
    endasm
    ENDSUB
    SUB Wr_Word '__PARAM1 is base, __PARAM2 is wordindex, __PARAM3 is value
    asm
      WRWORD __PARAM2,__PARAM3
    endasm
    ENDSUB
    SUB Wr_Long '__PARAM1 is base, __PARAM2 is longindex, __PARAM3 is value
    asm
      WRLONG __PARAM2,__PARAM3
    endasm
    ENDSUB
    Compiles into
    ''  *** COMPILED WITH PropBasic VERSION 0.00.04  09/01/2009 ***
    CON                                                          'DEVICE P8X32A, XTAL1, PLL16X
      _ClkMode = XTAL1 + PLL16X
      _XInFreq =   5000000                                       'FREQ 80_000_000
    ' LED PIN 16                                                 'LED PIN 16
    ' temp2 VAR LONG(3)                                          'temp2 VAR LONG(3)
    ' temp var long                                              'temp var long
    ' Delay SUB 1                                                'Delay SUB 1
    ' Rd_Byte FUNC 1,2                                           'Rd_Byte FUNC 1,2
    ' Rd_Word FUNC 1,2                                           'Rd_Word FUNC 1,2
    ' Rd_Long FUNC 1,2                                           'Rd_Long FUNC 1,2
    ' Wr_Byte SUB 3                                              'Wr_Byte SUB 3
    ' Wr_Word SUB 3                                              'Wr_Word SUB 3
    ' Wr_Long SUB 3                                              'Wr_Long SUB 3
    PUB __Program                                                'PROGRAM Start
      CogNew(@Start, 0)
    DAT
    Start                                                        'Start:
                MOV     temp,PAR                                 '  temp = PAR
                MOV     __PARAM1,PAR                             '  temp = Rd_Byte PAR,3
                MOV     __PARAM2,#3
                CALL    #Rd_Byte
                MOV     temp,__PARAM1
                MOV     __PARAM1,PAR                             '  temp = Rd_Word PAR,3
                MOV     __PARAM2,#3
                CALL    #Rd_Word
                MOV     temp,__PARAM1
    [color=red]                                                             '  'inline
                '       ASM                                      'asm[/color]
    [color=red]            mov     __temp1,#3
                shl     __temp1,#1
                add     __temp1,PAR
                rdword  temp,__temp1
                '       ENDASM                                   'endasm[/color]
                MOV     __PARAM1,PAR                             '  temp = Rd_Long PAR,3
                MOV     __PARAM2,#3
                CALL    #Rd_Long
                MOV     temp,__PARAM1
                MOV     __PARAM1,PAR                             '  Wr_Byte PAR,3,temp
                MOV     __PARAM2,#3
                MOV     __PARAM3,temp
                CALL    #Wr_Byte
                MOV     __PARAM1,PAR                             '  Wr_Word PAR,3,temp
                MOV     __PARAM2,#3
                MOV     __PARAM3,temp
                CALL    #Wr_Word
                MOV     __PARAM1,PAR                             '  Wr_Long PAR,3,temp
                MOV     __PARAM2,#3
                MOV     __PARAM3,temp
                CALL    #Wr_Long
                OR      DIRA,LED                                 '  LOW LED
                ANDN    OUTA,LED
                MOV     temp,#1                                  '  FOR temp = 1 TO 20
    __FOR_temp_1
                AND     LED,INA WZ, NR                           '    LED = ~LED
        IF_NZ   ANDN    OUTA,LED
        IF_Z    OR      OUTA,LED
                MOV     __PARAM1,#500                            '    Delay 500
                CALL    #Delay
                ADD     temp,#1                                  '  NEXT
                CMPS    temp,#20 WZ, WC
        IF_BE   JMP     #__FOR_temp_1
        '  'temp2(2) = temp
                '       ASM                                      'asm
                '       ENDASM                                   'endasm
                MOV     temp,#0                                  '  FOR temp = 0 TO 2
    __FOR_temp_2
        '    'temp2(temp) = temp<<3
                MOV     __PARAM1,temp                            '    __PARAM1 = temp << 3
                SHL     __PARAM1,#3
                '       ASM                                      'asm
                mov     __temp1,#temp2
                add     __temp1,temp
                '       ENDASM                                   'endasm
                ADD     temp,#1                                  '  NEXT
                CMPS    temp,#2 WZ, WC
        IF_BE   JMP     #__FOR_temp_2
                MOV     __PARAM1,_5000                           '  Delay 5000
                CALL    #Delay
                JMP     #Start                                   '  GOTO Start
                JMP     #$                                       'END
    Delay                                                        'SUB Delay
                MOV     __TEMP1,CNT                              '  PAUSE __PARAM1
                ADD     __TEMP1,_1mSec
                MOV     __TEMP2,__PARAM1
    __L0001
                WAITCNT __TEMP1,_1mSec
                DJNZ    __TEMP2,#__L0001
    Delay_ret                                                    'ENDSUB
                RET
    Rd_Byte                                                      'FUNC Rd_Byte '__PARAM1 is base, __PARAM2 is byteindex
                ADDS    __PARAM2,__PARAM1                        '  __PARAM2 = __PARAM2 + __PARAM1
                '       ASM                                      'asm
                '       ENDASM                                   'endasm
    Rd_Byte_ret                                                  '  RETURN
                RET
        'ENDFUNC
    Rd_Word                                                      'FUNC Rd_Word '__PARAM1 is base, __PARAM2 is wordindex
                SHL     __PARAM2,#1                              '  __PARAM2 = __PARAM2 << 1
                '       ASM                                      'asm
                '       ENDASM                                   'endasm
    Rd_Word_ret                                                  '  RETURN
                RET
        'ENDFUNC
    Rd_Long                                                      'FUNC Rd_Long '__PARAM1 is base, __PARAM2 is longindex
                SHL     __PARAM2,#2                              '  __PARAM2 = __PARAM2 << 2
                '       ASM                                      'asm
                '       ENDASM                                   'endasm
    Rd_Long_ret                                                  '  RETURN
                RET
        'ENDFUNC
    Wr_Byte                                                      'SUB Wr_Byte '__PARAM1 is base, __PARAM2 is byteindex, __PARAM3 is value
                '       ASM                                      'asm
                '       ENDASM                                   'endasm
    Wr_Byte_ret                                                  'ENDSUB
                RET
    Wr_Word                                                      'SUB Wr_Word '__PARAM1 is base, __PARAM2 is wordindex, __PARAM3 is value
                '       ASM                                      'asm
                '       ENDASM                                   'endasm
    Wr_Word_ret                                                  'ENDSUB
                RET
    Wr_Long                                                      'SUB Wr_Long '__PARAM1 is base, __PARAM2 is longindex, __PARAM3 is value
                '       ASM                                      'asm
                '       ENDASM                                   'endasm
    Wr_Long_ret                                                  'ENDSUB
                RET
    _5000            LONG 5000
    LED              LONG 65536
    _1mSec           LONG 80000
    __TEMP1          RES 1
    __TEMP2          RES 1
    __PARAM1         RES 1
    __PARAM2         RES 1
    __PARAM3         RES 1
    __PARAM4         RES 1
    __PARAMCNT       RES 1
    temp2            RES 1
    temp             RES 1
    CON
    From the inline code (red) it is clear that there better be native basic statements to access hubram.
    Proposal:
    · value = Rd_Byte address[noparse][[/noparse],byteindex]
    · value = Rd_Word address[noparse][[/noparse],wordindex]
    · value = Rd_Long address[noparse][[/noparse],longindex]
    ··Wr_Byte address[noparse][[/noparse],byteindex],value
    ··Wr_Word address[noparse][[/noparse],wordindex],value
    ··Wr_Long address[noparse][[/noparse],longindex],value
    When this is available together with the indexed variables, then we have a minimal basic that can do
    some real tasks.
    regards peter
  • jazzedjazzed Posts: 11,803
    edited 2009-09-01 23:24
    I don't know.
    regards peter
    Jon is right. It's a Propeller instruction pipe issue; without "some instruction" between the modifier and it's target, the sequence will fail.
    --Steve
    Propeller Tools
  • SapiehaSapieha Posts: 2,964
    edited 2009-09-01 23:58
    Hi
    Bean (Hitt Consulting)
    Very nice work...
    Ps. it is posible You write litle manual ... On words that can be used and syntax to them
    Regards ChJ
    For every stupid question there is at least one intelligent answer.
    Don't guess - ask instead.
    If you don't ask you won't know.
    If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
    Sapieha
    edited 2009-09-02 06:40
    Hi Sapieha,
    You can look at the SXB help file for syntax (attached).
    That should give you enough info, particular on the loop contructs.
    Many commands are not implemented yet and some never will
    because the Propellor is very different from SX.
    regards peter
    chm
    561K
    sxb.chm 561.2K
    edited 2009-09-02 14:32
    Hi Peter Verkaik
    Thanks .... But.
    Look on atached picture.
    Regards.
    ChJ
    Sapieha
    1323 x 679 - 158K
    edited 2009-09-02 14:49
    It works for me.
    Maybe you need to install the sxkey IDE software.
    http://www.parallax.com/tabid/460/Default.aspx
    regards peter
    edited 2009-09-02 14:55
    I just downloaded the sxb.chm file, and it works. I do not have the SX IDE installed. If you open up the References, the commands are listed there.
    Ray
  • John AbshierJohn Abshier Posts: 1,116
    edited 2009-09-02 15:07
    I get a "Navigation to web page was cancelled." error message. OS is Vista Home Preminum 64 bit.
    John Abshier
  • hover1hover1 Posts: 1,929
    edited 2009-09-02 15:16
    Even after downloading to a local drive, I get the same error.· I do have SX·IDE loaded.·· XP·Media Center SP3·32 bit
    John Abshier said...
    John Abshier
    Do the examples work for you as well?
    Sapieha, sometimes the regional settings have to be US.
    I had that problem some years ago. I now run WinXP SP3 and
    have no issues using Dutch regional settings.
    regards peter
    edited 2009-09-02 15:20
    Get the help file as pdf from first post (sxb.pdf)
    http://forums.parallax.com/showthread.php?p=597707
    regards peter
  • Agent420Agent420 Posts: 439
    edited 2009-09-02 15:23
    I don't have Vista, but here's the MS KB on that issue...
    edited 2009-09-02 15:25
    Yes, I spoke to soon, I did not try to open any of the commands. When you try, nothing happens, the file does not get opened. So, their is a problem.
    Ray
    edited 2009-09-02 17:59
    I am confused about "web" error message when I downloaded the help file to my PC.
    John Abshier
    edited 2009-09-02 21:44
    Just trying to do
    temp = 2999
    compiles into
    mov temp,_2999
    but shouldn't that be
    mov temp,#2999
    which fails (constant too large)
    So it seems every constant > 511 needs to be preloaded in a variable
    myConst long 2999
    then use
    temp = myConst
    Edit:
    Just noticed, _2999 is a preloaded variable with value 2999
    regards peter
    Post Edited (Peter Verkaik) : 9/2/2009 9:53:02 PM GMT
    edited 2009-09-02 22:20
    If the preloaded variable is moved to a seperate DAT section,
    the mov temp,_2999 must be replaced by
    rdlong temp,@_2999
    DAT
    _2999            LONG 2999
      CogNew(@Start, 0)
    DAT
    Start                                                        'Start:
                RDLONG     temp,@_2999                               '  temp = 2999
    Saves 1 long in cog ram for every constant > 511 (but speed becomes slightly less)
    Proposal: put all CON values > 511 that are defined before PROGRAM Start
    into a seperate DAT section and use RDLONG to load these constants.
    regards peter
    edited 2009-09-02 23:40
    While it would save one long in cog ram you take a bit hit on speed; 4 cycles for MOV versus 7 to 22 with RDLONG. PropBASIC will ultimately use LMM so this becomes moot.
    edited 2009-09-03 06:16
    Hi Jon,
    For small drivers LMM may not be necessary. But I thought of an alternative.
    If DATA is implemented (it doesn't work currently) I could use
    myConst: DATA LONG 2999
    All DATA must appear before PROGRAM Start (or after the basic program) and
    is placed in a seperate DAT.
    Then I can use
    temp = Rd_long @myConst
    where Rd_long (or LREAD) is a native·basic statement·to·read·a long from hubram.
    BTW. this DATA could also be used to have external variables.
    I could do Wr_long @myConst,temp
    regards peter
    Post Edited (Peter Verkaik) : 9/3/2009 6:24:31 AM GMT
