hyperterminal setting output pin high without using Basic stamp editor
I want to use Hyperterminal using the basic stamp homework board in a stand alone mode.
I want to control the board through the hyperterminal.
For example:
I want to set output pin 14 high using the hyperterminal
Can I type in hyperterminal· HIGH 14 and set the output pin?
I tried it and does not work.
Do I need the basic stamp to be running a program?
I searched through forums and could not find the information.
Any reference or information will be useful.
For example:
You could write a program and load it to the Stamp to interpret input from Hyperterminal. I'll bet there's a FAR easier way to do whatever you're trying to do, though. What's the project?
Don't worry. Be happy
' {$STAMP BS2} ' {$PBASIC 2.5} cmd var byte thePin var nibble main: debugin cmd ' Input a byte from the programming port if cmd = "H" then ' Is it "H"? debugin dec thePin ' If so, read a decimal value delimited by a non-digit high thePin ' Set that pin high elseif cmd = "L" then ' Same thing for "L" and setting the pin low debugin dec thePin low thePin endif goto mainNote that this code does no error checking. That can be added.
Your idea worked.
Only change I had to make was to make thePin Var nib instead of nibble.
Thanks.
Sylvie,
I am trying to write a higher level program with Visual Basic to work with the homework board.
I am trying to understand how BS2 works so that I can write a program in Visual Basic.
I wanted to know whether a program needs to be running in the board or the BS2 was intelligent enough to work directly with a hyperterminal.
From Mike's answer and yours I understand that one has to run a program in the board to be listening to the serial port for the hyperterminal to work.
I also saw in the web site information on tokenizers which I think can be used with Visual Basic.
I will read some more on this.
Thanks.
Vijay
