Has anyone tried to build a Verifier for RJ45? or is it possible?
Daniel Mueth
"Just plug it in and let's see what happens"
Daniel Mueth
if you mean a cable checker, then a stamp or just some simple discrete logic could do it - piece of cake.
or do you mean data-stream validation running at full bore?
please be more specific, thanks
- Howard
DogP
It wouldn't show if the pairs were shorted anyway, it wouldn't show if the wires in a pair were swapped over and you would have to watch for C/O leads.
I supose you could put a batch of known resistances, high enough to mask out the wires resistance, and with careful choice of values the faulty pair could be identified.
ie 1K between the wires of one pair, 2K btwo the next pair, 4K ......
Then at one end you would expect 1K+2K+4K+8K = 15K. (I haven't got my brain rounf what a C/O lead would give, but a Un C/O converter lead could be made up)
But as stated little testers are available and would have housings etc for the toolbox survival.
Style and grace : Nil point
You should use some drive limiting resisters in case you run into a dead short between wires. That way you won't heat up your prop.
You could use just spin to send out the square waves (just increment a range of 8 I/O pins) You could use counters to detect the frequency of each received. Check out:
http://www.parallax.com/go/counters
Or, if you wanted it real quick and dirty, you could just connect the far end to some LEDs and just watch it count in binary. Of course, you would have to use a low enough frequency to actually see them blink.
No if you want to test the quality (capacitance & length) of an RJ45, then I would look to Phi Pi for suggestions as he has a real good handle on signal issues.
Doug
Post Edited (hinv) : 8/30/2009 4:39:03 PM GMT
Daniel Mueth
