VGA output is a tiny bit bad, any ideas?
Hi guys,
I am working on a homemade circuit board using the same schematic layout as the demo board for my VGA output.· It works good but there are times when certain areas of the display are a bit scrambled.· About the best way to describe it is that in the areas of display that are bad, it looks like a different font - perhaps normal instead of bold.·
The bad area is not always in the same place.· If I take my finger and rub it accross the surface mount resistors, I can make bad areas and I can make bad areas look good.· This makes me think it is a "problem" with my circuit board or the construction thereof.·
I am thinking that perhaps a coating on the board would fix the problem but don't have anything to try.·· But, even if I did have something, I would ask here first just to make sure.·
Does anyone have any idea what could be causing this?·
Chris
Chris
Does the same thimg happen if one of the VGA demo progs are run or is it just with yours?
Style and grace : Nil point
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
As for bad solder joint, certainly possible, but the force I am applying to the resistors is a very light touch.· In any case, I will hit each of the pads with a soldering iron to see if that clears things up as well.
To clarify, I am an absolute rookie with electronics, but have been tinkering for a couple of years.· I use decoupling caps on ICs because everyone tells me to.· Seeing the phrase "Decoupling" here makes me want to understand more about this.· Can someone explain what decoupling means relative to what might be happening with my circuit?
Chris
The wires, and tracks, form resistance and inductors and so should be as fat and short as possible. A good regulator IC will fight a lot of these problems, and cause a lot of them if they are not decoupled properly too!
These patches of "not nice video" are they horizontal, vertical or really blobs that can be moved?
Blobs would be the best way to describe them.· I am using text mode and I think the resolution works out to 100 chars by 48 lines (again, just an estimate as I have fogotten since setting up that part of the program).· The problem areas are around clusters of characters and the "Blob" does move. It can move on its own as in it is in a different place when I power up or it can be moved by running my finger over the resistors.
I don't know if it is bad enough to show up on a photo, but I will try to take a picture the next time it is very noticable.·
Thanks again!
Chris
The Hybrid board doesn't have a VGA connector so I quickly made something up to participate in the Turbulence Demo . I was able to use that ratsnest to run the Turbulence Demo with no problems( that I am aware of)
Re: Turbulence is the successor of craft. It's a microcontroller demo based on the Propeller chip from Parallax. External I/O consists of stereo sound (at line level) and a VGA signal.
www.linusakesson.net/scene/turbulence/index.php
Toby did a great job of explaining decoupling, but you might also want to browse this article on wikipedia if you still have questions.
en.wikipedia.org/wiki/Decoupling_capacitor
One other thing, when you touch your resistors, are you sure that you aren't charged up from dancing across a carpet, brushing balloons on your cat, rubbing elbows with Casimir Effect sweater-wearing passersby or something? I doubt that would have anything to do with it, but it's just a thought.
It is most likely that your use of standard timings in VGA is showing some
monitor sync peculiar reactions.
The finger may be 'shaping' the sync signals enough to slide into an acceptable range.
First, try another monitor if you have one, or try trimming the H/V sync pulse widths slightly.
Where is the error showing ?
Top of Screen ?
Left edge of screen ?
Please describe the symptom better and location.
jr
If the active part of your VGA has wrong timings and some of it falls into the sync/blanking bits then the monitor will suffer from timing problems and/or clamping problems (this where the monitor assumes black should be, and nails its levels to that point)
Stick in a bog standard "demo" prog and see if the problem is still there ( and get the monitor to do an "AUTO")
