Ethernet Connection to a prop
pacman
People,
Can someone recommend a 'pre-canned' module that would allow me to put the Prop on {cabled} Ethernet cheaply
I know of a few larger $ modules but ideally I'm after a cheap solution that would allow me to generate a magic packet to WOL {Wake On Lan} devices.. It doesn't need to do anything else.
WOL does not need the full 7 layer OSI model, just a subset. A link to WOL can be found hereen.wikipedia.org/wiki/Wake-on-LAN
Thanks in advance
Paul
The future is in our hands.
Which way to the future?
Thanks in advance
Paul
eg ucontroller.com/documentation/PropNICDoc.html code at obex.parallax.com/objects/196/ and a pre-made board for $20 www.futurlec.com/Mini_Ethernet.shtml
But I'm not an expert on the code. Others here will be able to help more. Though I do have dreams one day of hooking the triblade cp/m computer into the internet using one of these modules.
The latest enc28j60 driver can be obtained from the zip file at the bottom of harrisonpham.com/dp/proptcp.
Post Edited (Harrison.) : 8/27/2009 6:49:12 AM GMT
Style and grace : Nil point
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
http://www.sparkfun.com/commerce/product_info.php?products_id=9360
James
I had looked at both the Olimex units and the Sparkfun offering (but had forgotten about the PropTCP board). Hence the reason I asked so big thanks to all.
I've ordered one of the PropTCP boards (whose prices {after currency conversion} and postage to the land downunder was cheaper than the others).
Looks like I now get to play with the harrison spin object. Wish me luck (I may need it....)
Again, thanks to all replies
There a quite a few of us spread out here. I am between Gold Coast and Gosford regularly.
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
It would be great to combine both in a moderately priced controller!
Imagine a controller with built in video hardware, USB and ethernet....WoW.
Instant low-cost internet terminals and much more.
@Dr_Acula
Those Futurlec boards look pretty good for 20$
- Some mornings I wake up cranky.....but usually I just let him sleep in -
Not 'pre canned' but it looks easy enough.
It uses a propeller and a ENC28J60 for ethernet.
www.ladyada.net/make/ybox2/download.html
JMH
I have recently purchased MiiNe by Moxa and so I hope to test those out. They are more expensive than a WIZnet module, but more compact and offers some other advantages. It all depends on what you want/need for your project.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
I havent tried mine out yet....
Doug
Doug
Have a look also at Tibbo modules !!!
The EM203+RJ203 bundle is €40+vat. It comes preprogrammed as a serial device server, but with a firmware upgrade you can switch it to TIOS (basic programmable device).
When the IO and/or program storage demand grows the EM1000/EM1206 come in. These are expandable with the WiFi option, that can run the same time as the wired one. Many protocols/functions are supported by the OS, the others can be programmed. The TIOS have al the tools/commands/instructions to manage the tcp/udp·connections and the first feeling is that everything is possible.·I have one EM1000 to test/reserch its capabilities and it looks a really nice device.
I recommend· everyone to have a read of the hardware and basic manuals. The features summary doesn't really express the whole potential that these modules have.
· Propeller Object Exchange (last Publications / Updates)
The enc28j60 still seems to be the most cost effective solution. The chip costs $3 in single quantities, comes in an easy to use 28pin soic/dip/ssop package, and requires a very minimal amount of external components. It's only expensive when you buy prebuilt breakout modules.
For projects like a simple WOL magic packet sender / receiver, the enc28j60 is the optimal choice. You would have to do just as much work, if not more, with the other chips.
