Boe-Bot with Spin Stamp
So I won this Boe-Bot thing at the Expo...
But, "I'm not going back to Basic", and yes, you can quote me on that!
I already gave the Stamp thing away to Vaati at the Expo...
Anyway, I'm going start by using a SpinStamp (that's been on the shelf about a year now...)
to get it going with the supplied board..
Has anybody else done this?
The datasheed for the SpinStamp says you need a PropClip, but I remember from before that I can just solder on a header and use a PropPlug...
I think I see one typo·in the SpinStamp datasheet that confused me for a second...
It says the VIN->VDD voltage regulator is a LM2937IMP-3.3, but I think it must be something like LM2937IMP-5.0
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
The SpinStamp has a 5V regulator so it can supply regulated 5V just like other Stamps. It also has an internal 3.3V regulator for the Propeller.
Post Edited (Mike Green) : 8/27/2009 2:45:11 PM GMT
PS: If you looke at the SpinStamp datasheet schematic, you'll see both regulators have the same part#... That's what threw me for a second...
