Simultaneous calls to an object method
Still wrapping my head around some of the parallel processing ideology and just thought of this...
Is it possible that a Prop app has a cog that contains some public methods, and several other cogs have calls or references to those methods?· If so, could there then be a case where several cogs attempt to call the same method in another cog at the same time?
I'll try to come up with a good program example, but the question relates to something like this:
Cog 1 has a public method named 'Callme'
Cogs 3,4 and 5 all contain code that references the 'Callme' method in Cog 1.
A situation developes where cogs 3, 4 and 5 all attempt to run the 'Callme' method in Cog 1 at the same time.
Is that possible?· What would be the result?· Would there be some kind of priority given based on cog id or similar?
it is different
everytime you start a new cog by using the command cognew
the COG-RAM of another cog is loaded with the SPIN-interpreter and the interpreter starts fetching spin-tokens and parameters
from HUB-RAM and is interpreting the spin-tokens
This means your method "Callme" is stored ONE time in HUB-RAM and then the SPIN-tokens are fetched from 1-8 cogs to be interpreted
Thereby every cog uses his own stack
if something does interfere with each other depends on the OBJECTS but NOT on the cogs !
global variables are accessible allover ONE object (= *.spin-file)
so if two methods which are stored in the same object access the same global variable
If methods are running in DIFFERENT cogs then
the methods will interfere on this variable in an mostly unpredictable way as you would have to calculate the executiontime of both methods
(and everything that has been executed before) in every loop to see which method will be first to reach the point of accessing the variable
"normal" global variables are NOT accessable across OBJECTS (but well accessable across cogs as long as the methods running in the cogs are from the same object)
Variables in the DAT-section are accessable across OBJECTs and here you have to use a lockmechanism too
This might be confusing. You will get it clear by playing around with different configurations.
Play around with some simple methods belonging to one object but start the methods in different cogs
then distribute the methods M1 and M2 over two different objects ObjA.spin ObjB.spin and try to access the method M2 from inside ObjA.spin
etc. etc.
best regards
Stefan
In your example, if cogs 3, 4, and 5 have refrences to Callme, Callme will be executed in those cogs, not from cog 1.
So the problem turns into a shared variable problem. So if you are updating multiple variables then you have to worry about updating overwrite probelms. which is what locks are meant to protect.
For an example look at http://forums.parallax.com/forums/attach.aspx?a=34061 this object is meant ot be included in multiple other objects. It is coded to start 1 cog for all opies of this objects and multiple cogs can call the pub routines. The shared variables are protected with locks and locks are also used to protect against the asm cog being asked to do multiple things at the same time by different cogs.
That said, it's common practice for an object to make use of a cog to do most of its work where there's a start and stop method that takes care of initializing the new cog and any shared variables (and stopping the cog if needed). Most of the other methods are interface routines that are called from other objects and communicate with the "hidden" cog that's doing most of the work.
Separately you have a multi-cog /data problem if multiple cogs can access the same variable. This could be multiple cogs accessing a VAR variable in 1 object, or multiple cogs accessing a DAT variable in multiple copies of an object.
What nobody has mentioned so far is the HUB Round Robin access.
Yes there are potential problems LOGICALLY for two cogs to access the same variable. But NOT LOGISTICALLY.
Cogs cannot access the HUB RAM simultaneously. Each cog has EXCLUSIVE access to the variable when its turn comes
to be able to access the HUB.
The problem of LOGICAL access is up to YOU. It's perfectly fine for instance to have one cog writing the variabel while another
reading and due to the HUB round robin access style there is no LOGISITCAL problem at all.
If you have both cogs write the variable then AGAIN there is no problem if that is what you want. Due to HUB access
both CANNOT try to write the variable at the same time. BUT....you might have LOGICAL problems if your program LOGIC
does not work this way......BUT...this is up to you.
Where there is a problem LOGISTICALLY is when there are MULTIPLE variables that need to be EXCLUSIVELY accessed
by a cog. Hub round robin access only guarantees exclusive access to one LONG from the HUB.
If you need to maintain exclusive access over MULTIPLE LONGS then you need to ensure exclusive access over multiple
round robin cycles.....this is achieved with the aide of LOCKS....see LOCKNEW, LOCKCLR, LOCKRET and·LOCKSET in the manual.
Also see page 24 in the manual regarding hub access.
Samuel
P.S. in PASM each cog can also have its OWN local variables which are only in that cog even though they appear
in the same DAT area they would be part of the PASM code and thus become part of the cog RAM and are thus
only local to the cog and cannot be accessed by other cogs at all.
Post Edited (SamMishal) : 8/27/2009 4:45:29 AM GMT
Post Edited (Agent420) : 8/27/2009 11:01:38 AM GMT
Spin locks, as their name implies, cause a code thread to "spin" when attempting to access a common resource that is currently in use be another CPU (or COG in this case). This is the reason Mr Chip Gracey included this mechanism in the SMP architectured Propeller :- to allow multiple COGs access to a common "location" that needs to be protected for single update access. When the possibility of conflict arises or to avoid infinite loops, spin-locks are often organised into a hierarchical structure; based on the order of operations/actions that need to occur for the protected resource.
Multiple CPU/COG access to common READ data is not of concern; WRITE access by more than one is - hence the need for the protection. In order to determine which CPU/COG should be the "last writer" is up to the implementation but the use of a hierachy makes this easier to enforce. Certain "rules" are adopted to allow enforcement of such a hierachy. To prevent "system hangs"; "spin-lock-timeouts" are often used. Common implementations of these involve a mechanism called STOMITH.
STOMITH (Shoot The Other Machine In The Head) is a technique used to cause a lock holder to "die" if is is deemed the lock has been held too long and could potentially lead to more serious system failure.
Implementing this kind of mechanism in a Propeller may prove problematic because there is no hardware based interrupt or NMI mechanism but; well crafted code that takes this into consideration could use some common flag/mask location, that, if set for a given CPU/COG ID causes the specific COG as flagged masked to execute a "REBOOT" (or whatever). How to release/recover the resources and actions performed by the "hung" COG is left as an exercise for the reader.
Cheers,
Harry E.
