"word ^= 1 << bit" should do the trick.
1 << bit makes a 1 bit mask from the bit number you want and it's then XOR'd against your word variable to invert only that specific bit
lt's not particularly silly, is it?
Phil
Don't want to be too picky here, but Holland simply reinvented genetic algorithms based on the real thing!
Thanks for the PDF. I try to avoid that type of stuff because its not in my language, and I end up confused, rather than than thinking it thru from first principles. But thanks, I'll have a look at it.
TIA David Young
term.bin(Chromosome[noparse][[/noparse]Current_Population_Size] ^= 1 << (|| rr.random // 16+1),16)
David Young
Your variable names intrigue me. Are you writing a GA for the Prop?
BTW, you can copy and paste your code here, www.phipi.com/format, to convert it to something that displays better in the forum.
TIA David Young
The fact that you're matching bit strings leads me to infer that you're using a Michigan (John Holland)-style learning classifier system. Correct?
Post Edited (Phil Pilgrim (PhiPi)) : 8/27/2009 2:31:26 AM GMT
Who's John Holland?
TIA David Young
TIA David Young
