Todays special- Prop Plug.... — Parallax Forums
Don MDon M Posts: 1,654
edited 2009-08-25 17:44 in General Discussion
What is the difference between this Prop Plug item code 32201 and the USB2SER Development Tool item code 28024 ? They look the same to me and look to do the same thing. But at different prices.
    Functionally the two are almost the same. The connections are different. Some of the Propeller boards have two sets of connections, one for a Prop Plug and the other for a USB2SER and you can install a 2nd set of header pins to use a USB2SER adapter instead of the Prop Plug.
