which microcontroller to use? — Parallax Forums
tatertater Posts: 13
edited 2009-08-24 13:56 in Robotics
we are planning a bot that will use two servos to hunt for a radio beacon, which microcontroller should we use? I knoew everyone has their favorite but we want the cheapest, simplest controller available, I was looking at parallax SX series but maybe I should go with the basic stamp 2?
    edited 2009-07-22 02:39
    The SX series is certainly cheap and works well. You can use SX/B (a Basic compiler) to help with the programming.
    On the other hand, the Stamps are really simple to use, but they're more expensive.
    Do consider the Propeller. The Protoboard is only $30.
  • SRLMSRLM Posts: 5,045
    edited 2009-07-22 03:29
    Depends on how much you're willing to program. Some more details about your project and skills will help.
  • tatertater Posts: 13
    edited 2009-07-22 03:39
    im looking thru the options now, and the stamp 2 OEM looks like the cheapest option.
    what we are doing is taking a radio beacon in a remote location, using the stamp to run 2 hobby servos to home in on it using 2 recievers with dipole antennas, looking thru the documention about it and it looks like a good match.
    edited 2009-07-22 03:46
    An SX Protoboard runs $15, but you need a 1-time purchase of an SX-Key for $50. Everything else (software, manuals) you can download.
    A Propeller USB Protoboard runs $40, but is ready to go with only a few cables (mini-USB to USB, power cube or battery pack).
    A Stamp Super Carrier Board is $20 and you may need a USB to Serial adapter ($20 with cable) if you don't already have a compatible one. You'll also need a Stamp module ($50 to $80 depending on features).
    edited 2009-07-22 03:50
    Have a look at the BS1 also. It's limited in how big a program it can hold (about 256 bytes), but it sounds like you have a pretty simple application. It's cheap ($30), small, and low-power.
    edited 2009-07-22 03:59
    ok, confused.
    where are you seeing the BS1 for $30? also on recommendations it says
    BASIC Stamp Modules
    OR purchase one of the minimum requirement options and download manuals online:
    I have a serial cable, breadboard and power connection will have to be custom for our project anyway.
    So I'd need the BS2 OEM for $30 or do i need a stamp with it?
    edited 2009-07-22 04:50
    BS1: www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/CategoryID/9/List/0/SortField/0/Level/a/ProductID/3/Default.aspx
    I was just suggesting that you look at it. It's quite limited in terms of program size, but your task seemed simple enough. The BS2OEM is probably more suited to your task.
    The BS2OEM is the Stamp, just using non-surface mount parts to form a larger "module" than the BS2 24-pin Module.
    edited 2009-07-22 14:53
    good, yeah, the size is fine, power will gome from a 7ah gel cell so size is not too relative. the BS1 looks like it would bareley work, as i'd end up using 4 pins for two servos, giving me only 4 pins for directional input. in theory i think i only need two, but it would be nice in case i need more.
    I am off to the oshkosh airshow and wont be back for 3 weeks, i'll probably be ording it when I return.
    oh, I've been vauge about the application. directed rocket recovery system. a steerable parachute, and possibly guidance for the rocket itself in later design phases. if the BS2OEM works we shoudl be able to grab a few homework boards and use them instead.
    oh I bet you'd like to see some video of our project http://www.youtube.com/watch?v=Yaz_t6IBAKs
    Post Edited (tater) : 7/22/2009 3:16:23 PM GMT
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-07-27 23:52
    > youRocketTube
    Gads, Tater! What a beast that thing is! Did you set off NORAD alarms on launch? [noparse]:)[/noparse])
    - Howard
    ... who never graduated past an Estes D engine...
    edited 2009-08-16 23:29
    CounterRotatingProps said...
    > youRocketTube
    - Howard
    nope, had to get an FAA waiver plus the OK from the civlian and military ATC (standard procedure, easy peasy). aerotech I 284 for a motor, although that does have a removeable motor mount for just about any size engine you want.
    but thats not what the stamp is for, I figgure i need about 3-4 of them for recovery guidance for the HALF scale (18 ft long 40" dia)
    anyone wanna do the programming? hey parallax? want some free* advert space?
    *free as in send me some stamps to get it working [noparse]:)[/noparse]
    edited 2009-08-16 23:34
    I can see Parallax written long-wise on the side now [noparse]:)[/noparse])
    well, forget the freebee stamps, why not go full scale and go for the next X-prise? hehehe
    edited 2009-08-16 23:58
    because the X-prize aint my goal [noparse]:)[/noparse]
    and probably wouldn't give parallax full ad space, unless they want to start ordering all the supplies i need(about $2k for the half scale, $20k for the full) but I could see their name full length along the leading edge of one of the fins for the hardware i'd need from them
    granted, i'd prefer to sell off space on the rocket in 2x4ft slots, but i'd be flexible.
  • sylvie369sylvie369 Posts: 1,622
    edited 2009-08-17 00:21
    Hey, Tater, welcome to these forums (I know you from the WOOSH mailing list). Congratulations on the EAA presentation. I spoke this past week with Lee Siudzinski, EAA VP of Education,·and he's pretty excited about the EAA's expansion into space-related craft (as a result largely of White Knight/Spaceship Two).
    You know that the Wisconsin Space Grant Consortium contest three years ago was high power spot landing, presumably using steerable parachutes, right? No-one got the steerable chute thing working properly - my group had successful flights with simple radio-controlled deployment of normal parachutes, and won a "non-engineering" prize. Are you planning to steer the whole thing, or just the capsule, using a more standard chute for the booster part? I assume you're going to use radio control for steering, right? You're not planning on autonomous guidance?
    The best design that I saw was from a UWM team, and had servos mounted in a parafoil-style parachute, and the servos were intended to steer the chute by selectively collapsing cells in the parafoil. That solved what seems like the biggest issue to me: how to prevent the mechanism from being torn apart by the stress of parachute deployment. I'd think that the sudden yanking on the shroud lines that happens when a chute opens is pretty likely to damage even a very high quality servo (though I admit I haven't looked into the real expensive upper end of the servo price range). Unfortunately, the UWM rocket was destroyed when they were accidentally given a motor (K550) with an ejection charge installed, rather than a plugged one. Their rocket wasn't designed for motor deployment. The results were ugly.
    edited 2009-08-17 03:32
    sylvie369 said...
    heh, we should move this to another forum, but i'll wait till the moderators yell first, as this is on topic.
    I can understand the headaches on guideable(?) recovery, havent researched it yet, like the collapsing cells idea, and might steal it. and we do plan on autonomous guidance in the future, but we figgured doign the recovery first will soften the paranoids to the active guidance on large model rockets. I bet bunny would like it if we could steer a rocket safely away from people in a lawn dart moment.
    back on topic, 2 BS1s for fin guidance, one for capsule recovery, another for booster recovery(4 total maybe). ham radio for beacons with modified foxhunters for telling the stamps where.
    I am planning on having a couple 7ah gel cells on the half scale for power, hybrid motor with an avg thrust around 1000n and will need to use bong i think. when i get back to the HQ (dogsitting now) i'll be laying out my master plan for the next 6 months.
    edited 2009-08-17 05:13
    sylvie369 said...
    I'm sure this has been thought of before, but why is this a big problem. Assuming that the rocket is fairly large (aka, indoor space isn't much of a concern) then can't you have a retractable bar that is braced against the structure of the rocket? Basically, it would have all the lines of the parachute attached to it via a loop in the line, with the lines continuing on to the servos. The chute deploys, the bar is slammed into, and a few seconds later the bar retracts and the servos get a couple of inches of jerk.
    I tried to draw a picture, but it was in paint and it looked terrible.
    edited 2009-08-17 13:10
    SRLM said...
    I'm sure this has been thought of before, but why is this a big problem. Assuming that the rocket is fairly large then can't you have a retractable bar that is braced against the structure of the rocket? Basically, it would have all the lines of the parachute attached to it via a loop in the line, with the lines continuing on to the servos. The chute deploys, the bar is slammed into, and a few seconds later the bar retracts and the servos get a couple of inches of jerk.
    it's not a big problem, and if the rocket is designed well it shouldnt be a problem at all. your solution just moves the jolt from the servos to a big bar which would work. best would be to just have the servos interact with the shroud lines like a spagetti fork, no extra hardware(weight is an issue) no strain on the servos until activated, and least ammount of servos used. i think air and space mag has a recent article about steerable parachutes for payload delivery
    edited 2009-08-17 13:40
    Retracting a bar would be quite a feat in itself, I think. (and hey, it's an issue that keeps the thread on-topic!).
    It's doable, I imagine, and probably something that rocketeers should be working on, as it'd have quite a few applications. But whenever I think about this kind of thing, I run into the question "how do you have a part that is strong enough to hold up to those kinds of forces and yet can be moved?" (and keep in mind that it also has to be fairly light, and that the power supply for moving it can't be a big heavy thing either). Five years' worth of college rocketry competitions have shown me a lot of engineering groups' proposed solutions to these kinds of problems - and have shown me a lot of ways that things can go wrong:
    http://tinyurl.com/5dkba5
    http://tinyurl.com/563ard
    http://tinyurl.com/5cuaz5
    http://tinyurl.com/69lecz
    http://tinyurl.com/6pm9zw
    http://tinyurl.com/6yrrvk
    http://tinyurl.com/5k8dek
    http://tinyurl.com/6qr4a7
    http://tinyurl.com/58wcnw
    http://tinyurl.com/5bkuc2
    edited 2009-08-23 22:23
    sylvie369 said...·it's an issue that keeps the thread on-topic!
    Tater, Paul,
    I don't think you guys have posting anything off topic or out of the forum's scope... I mean, a rocket with electronics is just a robot without treads and gripper arms, isn't it? scool.gif
    Aren't the bunge cords on the chute supposed to buffer that??·· Cool videos --- yikes, the one's with chute failure are *painful* to watch!
    cheers
    - Howard
    (itching for some nichrome wire)
    edited 2009-08-23 22:51
    Tater, Paul,
    cheers
    - Howard
    only if the bingie cords can take up all the stress and do not pass on any that is more than the servo can handle
    I've been busy, might be getting something interesting up soon
    edited 2009-08-24 10:53
    In most cases, the lines going to the chute have only a little stretch to them. Bad things happen if there's a lot of elasticity in the recovery system. Even if they were just long bungee cords or really strong rubber bands, there's so much pull on them that there'd be a lot of stress on the servos.
    Some kind of rigid device to absorb the yank and then be retracted would be a good alternative, if you could figure it out.
  • ManetherenManetheren Posts: 117
    edited 2009-08-24 11:48
    Why not have the chute lines go through a hole in the servo arm and then connect to a bar behind the servos. Once the shute is deployed it would pull on the bar with the line slipping through the servo arm then the servo could move and pull the line.
    Tia'Shar Manetheren
    shhhhh! I was already thinging that!
