PSM: AIgeneric (almost) - Need help
Oldbitcollector (Jeff)
My PASM skills are non-existent, and I suspect I need to load the character data
into the assembly section of Ray's driver to make this work.
I've loaded the 8x8 character set into eightfonts, now how do we switch them
in instead of the rom font? I can't find where the rom font is accessed.
I'm using the "tilt_contro_demo" for text demo here.
Edit: Found one issue, fonts now load into "eightfonts", duh..
Can anyone assist?
OBC
New to the Propeller?
Post Edited (Oldbitcollector) : 8/24/2009 4:48:20 AM GMT
Can anyone assist?
OBC
OBC
Anyway, the ROM font starts at $8000_0000 so you might find that as a magic number somewhere, but you might also find the high bit getting shifted in to offset to the start of the ROM font table.
To be honest, I don't see any problem with a 16x16 font side. (the more the merrier)
Thanks for the input, adding it to my debugging. [noparse]:)[/noparse]
OBC
BTW: I was at Staples today and picked up a palm pda leather case real cheap. With some small spacers the PSM is almost a perfect fit. It also had room for two extra SD cards. The only drawbacks are it is hard to use the power switch and you can't get to the reset button.
What electronics need - MORE POWER!!!!!!!
