schematic for a field strength SWR METER @ 400-450 MHz ?
Hello All
I need a schematic for a field strength SWR METER @ 400-450 MHz. ?
My recent project involves the Parallax RX/TX modules part#s 27980 and 27981. I need to remote mount the ANT. to fit the module to the enclosure I have made for both units.· My concern is the ext. cable length and the affect it will have on the SWR of the module.
I have found some stuff on this topic on the net, But they want my E-Mail address to see their schematic...Then·SPAM me with junk Mail's.
·Thanks in advance
_____________________$WMc%________
The Truth is out there············································ BoogerWoods, FL. USA
·Thanks in advance
As for the SWR meter - Not a clue, but I hope that tip helps. [noparse]:D[/noparse]
and a project article for an SWR meter: ok1tic.nagano.cz/?download=uWave%20PSV%20metr_EN.pdf.
You are the Man..... Just what I needed!!!
__Many_Thanks______$WMc%_________
If it is very long you will get a lot of loss at UHF frequencies if you use the wrong sort.
If just a few inches use the really tiny stuff as it's easy to work with...RG174 is what it's
called if I remember correctly.
The output of those rf modules is probably very weak, so it will take a really sensitive
swr meter to read it or you may not get full scale...but even if the meter barely moves
that is enough to trim an antenna for minimum swr with the meter set at maximum sensitivity
and in reflected mode...just trim and look for the lowest meter reading.
We use a meter called a Bird at work...it is good to about 3ghz and .1 to 10,000 watts.
Probably just cutting the antenna to the correct length and making certain the feedline is
properly connected will be good enough, the unit can probably take at least 3 to 1 swr
continuously without harm...and the difference between a 1:1 match and 3:1 match will
not be noticeable to you at all...especially with a very short feedline. If you are mounting
the antenna atop a metal case and if it is large enough to provide a good ground plane
then you can just use a 1/4 wave length of stiff wire for your antenna...if it is cut exactly
right and is on a suitably sized metal base you can get as low as about 1 to 1.3 swr.
It seems like a lot of work to make an swr meter for taking a single reading. Do a google
search on the name of the town where you live and 'ham' or 'amateur radio' and you can
find some local hams. One of them will have a meter and will be glad to have you over to
take your readings. He will also probably have some short lengths of RG174 in the junkbox
he will give you
phone number search on one of the phone book search engines to get the phone #.
eham.net has a ham call search engine you can use.
Look here for info about making simple ground plane antennas.
www.google.com/#hl=en&source=hp&q=1%2F4+wave+antenna+plans&aq=f&aqi=g10&fp=c9fe100d9e542c1e
We use a lot of antennas where I work. Mostly 2 types.. discones and microwave dish antennas.
The discone is a great vertically polarized antenna that has a low swr across a very wide spectrum
and they are easy to make yourself for frequencies 400mhz and up... there is no need
to even test the swr with these. The dish antennas we use are for 2.5 and 5ghz and cost just 50.00
They have 24db gain (that's a LOT)
- Some mornings I wake up cranky.....but usually I just let him sleep in -
ludens.cl/Electron/swr/swr.html
Tracy Allen
www.emesystems.com
LoL, I saw the emesystems url and since EME is an abbreviation for using the moon
for communications by bouncing rf signals off of it I surfed over to see all the cool
antennas and stuff
images.google.com/images?hl=en&source=hp&q=eme+moon&btnG=Search+Images&gbv=2&aq=f&oq=&aqi=
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Most SWR meters attempt to be loss-less over the band of interest by use of a directional coupler or some such magic. So they can stay installed in the feed line even at high power levels. That link I pointed to inserts the Antenna feed as one arm of an otherwise resistive 50 Ohm Wheatstone bridge circuit, and measures the voltage and phase difference across the arms of the bridge. Terribly lossy, so one would not usually want to leave it in the line, only for setup of an antenna at low power. It should also be useful for some purpose where VSWR reflects some physical quantity to be measured.
Tracy Allen
www.emesystems.com
This is great info. I never expected to get this much input on a " RF related topic " in a micro controller forum. This is great!!!
I have downloaded a ton of info from the sites "You'll" have provided.
The ext. cable is about 3/4"·long. Just enough to pass through the enclosure and keep a water tight seal. (a bulk head connector)
__Thanks Again_________$WMc%_________
Post Edited ($WMc%) : 8/24/2009 6:41:10 AM GMT
