Proper way to change the I/O pin used by an object? still stumped
I started with the propeller after UPEW, so I am still in the newbie category. I have been going through the manual, example programs, and tutorials in my learning adventure. Most of my time is being spent disassembling the code structure from the Sensirion SHT11 demo so I can make sense of each line. I am working on tweaking the code to read multiple sensors and have it working, but I know I am changing the datapin used by the Sensirion object the wrong way (I just keep re-starting the object with a different pin). I claim the newbie excuse for this mis-use of SPIN. So.......
What's the proper way to change the pins used by an object?
(I would prefer a response that tells me what direction to head rather than the straight answer as I know I will eventually figure it out, but I think I have been looking in the wrong places for the answer)
For example, the Sensirion object demo has:
sht.start(SHT_DATA, SHT_CLOCK)
and SHT_DATA and SHT_CLOCK are set as constants equaling 0 and 1.
How do I change the value of SHT_DATA during runtime? I have the clock (I/O 0) tied to 4 sensors using data lines on I/Os 1, 2, 3 and 4. So I simply want to leave the clock pin as I/O 0 and cycle the data pin through the 4 other pins.
Can I not do that because it is set as a constant earlier in the program? The manual says constants are set at compile time. Does this mean that constants declared in the code cannot be changed after compiling (in other words, during runtime)?
When I set SHT_DATA as a byte size variable and use a local variable (i) to count through the sensor pins, this doesn't work:
SHT_DATA:= i
However, re-doing the start command in my repeat block does:
sht.start(i, SHT_CLOCK)
I have tried several different ways with only getting various errors during compile. The manual isn't in plain enough English for me to capture which method I should be using to accomplish this. I started digging through the tutorials and the sticky example thread, but so far, nothing.
thanks in advance
Andrew Williams
WBA Consulting
Post Edited (WBA Consulting) : 8/23/2009 2:09:33 AM GMT
SHT_DATA:= i
thanks in advance
Andrew Williams
WBA Consulting
I had this issue myself, and found that one can use the DAT section to accomplish this.
As per your request, that is the only hint I will give you.
After I also ran out of ideas, the DAT section was all I had left,
and this method was not in any manual or thread.
Make sure you look up the DAT section in the manual, because it has a two fold use,
for assembly and for data.
WoOt :~o
Post Edited (Clock Loop) : 8/20/2009 8:28:30 AM GMT
with the sensirion-demo-code from Cam Thompson, Micromega Corporation
and both ways to define a variable "k" global byte and "i" local long do compile with propellertool 1.2.6 !?!
so which version of the propellertool are you using or maybe even some other SPIN-compiler ?
what kind of error-message do you get ?
best regards
Stefan
Clock Loop... Thanks for the tip. The DAT command was one of the things I thought might be a solution and will take a deeper look at it.
thanks!
Andrew Williams
WBA Consulting
It works great as it stands now. Running it on a prop demo board using P0 for clock and P1-P6 for the data lines of 6 sensors. Currently only using 2 sensors so 4 of the readings are showing invalid values (I'll be modifying the code to only display valid values or "---" so it's obvious when a sensor is not functioning). Using the VGA terminal option and displaying it on my Samsung 40" flatscreen.
When I have the start function in the beginning of the code (with the other start functions) as:
and change the value of "i" in the repeat section of my code, none of the readings are valid as if the SHT object is not using the "i" value to change which pin it uses for the data line.
When I put the start function inside the repeat block, it works fine. Isn't starting the same object over and over an incorrect method of doing this?
Attached is current code and a picture of the VGA output. Below is the main method which has the start and repeat functions mentioned.
Andrew Williams
WBA Consulting
Post Edited (WBA Consulting) : 8/23/2009 8:59:59 AM GMT
if you take a look at the code inside of the method start
THIS start-method does only some variable-assignments, setting up IO-pin-directions and toggle IO-Pins
in this case it is no problem to call it again and again. It would be a problem if the start-method would use a cognew to start a new cog.
Then you would run out of cogs all doing the same and interfere with each other
Your picture shows negative humidity. This seems to be wrong for me. Are you sure the negative humidity-values are valid ?
I guess as you only change the dataline all clocklines are parallel connected. This means all sensors get their clockinput
bitbanged all the time. I'm not familiar with the SHT-sensor. Does a reset bring the sensor back to working properly ?
If you have the call of the start-method outside the repeat-loop
how do you then change the dataline INSIDE the repeat-loop ?
another small hint:
you should not code
always as do it this way
add the actual value of cnt at the END of the expression to keep the time that will pass by between interpreting the spin-expression
and the REAL call of the PASM-command waitcnt (done by the interpreter) as short as you can
best regards
Stefan
Post Edited (StefanL38) : 8/23/2009 4:44:29 AM GMT
StefanL38:
--Thanks for the clarification about the start call. I was unaware if re-starting the same object over and over would be slowly eating away free space and would eventually prevent the program from running. I was aware about the repeating cognew problem, even though I have never used the command.
--As for the negative humidity, those are technically valid values because I only have two sensors mounted on my demo board. So 4 of the values are calculating off of null readings, which give you a temp of -39.4F and an RH of -4.6%. Since I know why those values show up, I ignore them, for now... In a finished state, those values would tell me that a sensor has been disconnected, however, my code will also recognize invalid values and display "---" in its place. (I mentioned this in the last post)
--Yes, the clocklines are all tied together and each device that does not have its dataline being used, is actually being continually held in reset because the data line has a pullup. (a reset is 9 or more clock pulses with the dataline high). This actually doesn't cause any problems, but I will modify the code to eliminate this continuous reset problem on idle sensors or change to bussing the data lines and changing the clock.
--A Reset refreshes the serial interface only, but typically clears any problems. I have actually eliminated the reset sequence from some programs and can get them to run without any problems. The reset makes it bulletproof and eliminates the need for extra error handling.
--Your question "If you have the call of the start-method outside the repeat-loop how do you then change the dataline INSIDE the repeat-loop ?" is exactly what I am looking for. However, your comments made me look back into the Sensirion object and the start method. I think I need to pull out the pin assignments from that method and create a "pinassign" method. The reset sequence would also be pulled into its own method. Then the start method would call both of those, but during my repeat sequence in my main program, I can call the pinassign method to change the pins as needed. I will have to try this tomorrow.
--Point taken on the waitcnt line. That line came from the demo code from Cam Thompson, so I assumed that it was done correctly and never thought to analyze it. I guess that's newbie lesson #57: Don't assume the code you're given is perfect.
Andrew Williams
WBA Consulting
I did change the wait routine when I used the sht, I found the wait period isn't as long as the spec allows and I sometimes got invalid readings. My wait code looks like
The only different is the wait time I changed 250 to 450, the spec says the time delay maybe upto 320ms, the 250 meant it wasn't long enough for the worse case.
