Composite Video Input
I am tossing around another idea for my project. I would like to have a composite video input and then record it directly to an SD card. Could anyone point me in the right direction, as I am assuming I need a dedicated IC to interface with.
Thanks!
Ryan
Post Edited (ry.david) : 8/22/2009 1:10:59 AM GMT
Thanks!
Ryan
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Even without considering the input requirements, the current speed record for fsrw is around 2MB/s (100MHz clock).· With NTSC that's max 130 samples per line, maybe 140 if you have deep enough buffers to stream continuously during both hsync & vsync.· Pretty low res.· And that would just be B&W.· If you're sampling color too, divide by two or three (depending on whether you want 2:2:2 or 2:1:1 sampling).
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
@ericball,
Thanks for the input. This is assuming uncompressed input, correct? I am wanting to take apart a cheap camcorder, or something that records to SD, and see how it is done.
Thanks!
Ryan
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
One problem we had was that we were sampling color video, and we didn't have a good comb filter in the circuit - only a low-pass filter. The amplitude of the chroma component is significant compared to the luma. I was running into a trade-off between a very noisy picture and a blurry picture. Also, the display we used had only 16 levels of gray, so a lot of detail was lost in the image. Needless to say we sort of abandoned that approach. Looking back on it, had we used a monochrome video source it may have looked a lot better.
Ken
