Tlv 2543 help needed.
· I cannot get the tlv object from the object exchange to work. I am not familiar with asm.
Can anyone· tell me how to setup the pins for the cs,clk, do,di,eoc. The program uses a config.spin which is gibberish to me.
I hooked it up on pins 15-19 as per tlv2543 pub start instructions.
I changed the start to· adc.start(cs,clk,do,di,eoc) with each pin as per instructions.·No luck. Any help apreciated.
I·am using the·8038 for about 6 months so I am familiar· with adc chips but the program has got me lost.
I am using the professional dev board.
Thanx
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
Thanx
Vcc (pin 20) and Ref+ (pin 14) 3.3V
Gnd (pin 10) and Ref- (pin 13) 0V
CS (pin 15) Prop
IOClock (pin 18) Prop
Datain (pin 16) Prop
Dataout (pin 17) Prop
EOC (pin 19) Prop
AIN0-10 (pin 1-9,11-12) Analog inputs
the pin numbers on the left are the pins on the tlv2543, when connecting to prop pins, put the prop pins in the right place in start()
}·· config.GetPin(CONFIG#TLV2543_DO), config.GetPin(CONFIG#TLV2543_DI),config.GetPin(CONFIG#TLV2543_EOC
This seems to indicate (cs,clk,do,di,eoc). Is this correct? You say put them is right place.
then you can just use somevar := adc.GetData(x) where x is the channel you want.
Hope that helps
Greg
cs=15········· 'chip 15
· do=16········· '···· 16
· di=17········· '···· 17
· clk=18········ '···· 18
· eoc=19········ '···· 19
I have di· and do reversed. Thanx
That got it. It's working
Post Edited (mosquito56) : 8/20/2009 6:35:32 AM GMT
