FullDuplexSerial Assistance Needed
Ok, how to start.·
I am currently using the FullSerialDuplex object from the object exchange and i am sending data (strings) out the .tx· i have been doing this successfully for a while now.· But what i want to do is also recieve data back.· I have done this in one program.
but all this gets me is one character.·
What if i want to recieve data like·· #1042,123,1513,1232,1220$
I was thinking that the # would let the rx know that it is the beginning and the $ would signify the end?
how do i get all this stored into a variable. or better yet, parse between comma's and store several variables.
i am stumped and would love to see an example
It's Only A Stupid Question If You Have Not Googled It First!!
repeat until ser.rx == "#" ' wait for start char ch := sock.rxtime(250) ' get response code if ch <> "0"
Post Edited (Mike Green) : 8/20/2009 5:09:56 AM GMT
edit: you'll probably have to have an OR on those two lines, since there are multiple possibilities for end of number ( "," and "$"). On a side note, if you have control over the serial stream you may want to put the $ first, just to be consistent with NMEA GPS strings. Also, if you do have control and you always know how many numbers are transmitted in a string, you might as well end it with another ','.
Post Edited (SRLM) : 8/20/2009 5:51:54 AM GMT
IIRC!
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Shows you the value of browsing through the index rather than searching. If at first you don't succeed, go browse. It takes less than a minute!
C:\Program Files\Parallax Inc\Propeller Tool v1.2.6\Examples\PE Kit\6 - Objects Lab
in similar cases do a search for *plus*.spin in directory "Propeller Tool v1.2.6" including all subdirectories.
By the way and somehow OT: the tool Instant File Name Search
scans my entire harddisk with over 360.000 files within 30 seconds if PC is not busy and in 3 minutes if PC is busy
After scanning searching for a filename is done in less than 1 second ! never wanna miss this tool again
best regards
Stefan
Post Edited (StefanL38) : 8/21/2009 9:26:19 AM GMT
