Runtime Error
In the bottom menu system, when I click on the "Show Active Threads" link, it gives the following error. Just thought I'd bring it to your attention. No reply needed.
Server Error in '/' Application.
Runtime Error
[font=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif ]Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
[/font]
Runtime Error
[/font]
PM me if other details are needed to address this error.
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
Andrew Williams
WBA Consulting
Seems to be an issue only when you are logged in.
Andrew Williams
WBA Consulting
Runtime Error
<!-- Web.Config Configuration File -->
<configuration>
<system.web>
<customErrors mode="Off"/>
</system.web>
</configuration>
<configuration>
<system.web>
<customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>
</system.web>
</configuration>
Chris Savage
Parallax Engineering
