ZiCog a Zilog Z80 emulator in 1 Cog - Page 17 — Parallax Forums
1141517192041
    edited 2009-08-19 11:27
    I've been putting in some debugging.
    PRI out_hdskport_null
    'Handle writes to the hdskport when no command is in progress
    'io_data should be a new command byte.
      case io_data
        hdskRead:
          UART.str(string("hdsk read"))
          crlf
    and
    PRI hdsk_get_rw_params
      printhex(io_data)
      crlf
      case hdsk_command_pos
    I get this much when typing I:, before it hangs
    hdsk read
    00
    00
    06
    00
    39
    F7
    added in another little tracker:
      printhex(io_data)
      crlf
      printhex(hdsk_command_pos)
      crlf
    yes, hdsk_command_pos increments each time as expected.
    hdsk read
    00
    01
    00
    02
    06
    03
    00
    04
    39
    05
    F7
    06
    Post Edited (Dr_Acula) : 8/19/2009 11:36:43 AM GMT
    edited 2009-08-19 11:57
    Heater: My i.dsk looks very different to yours??? Do I need anything in the cpm bios??? IIRC, my floppies are straight from the SIMH website.
    James: Can you try this (in PRI in_hdskport_read | r)
      sd_block := (drive_base[noparse][[/noparse]hdsk_drive+8]) + (hdsk_track * 32) + hdsk_sector
      err := sd.readSDCard(sd_block, @disk_buff, 128)       'read a sector
    replace "128" with "512"
      err := sd.readSDCard(sd_block, @disk_buff, 512)       'read a sector
    ·next try and offset @disk_buff[noparse][[/noparse]3] and back to 128 sector length
      err := sd.readSDCard(sd_block, @disk_buff[noparse][[/noparse]3], 128)       'read a sector
    How does cpm know about the drive geometry???
    · Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
    edited 2009-08-19 12:16
    Ok, working through that one.
    Geometry? It is part of the custom bios you insert into the cp/m code. Eg sector size, number of sectors. But, this is my theory, no mattery what is inside the simh parameters, if you have a huge file filled with E5, it should come back with the drive name, and if you do a DIR it should come back with no file. For instance, I have no idea what the drive geometry is of a floppy drive either. But I created a 32mb file filled with E5, called it DRIVE__B.DSK and this is what happens:
    A>B:
    B>DIR
    No file
    B>
    So, the same thing should work for drive I.
    I added this bit of test code:
    'Handle read from hdskport during a disk read command
    'This read triggers the actual disk sector transfere
    'and must return an error code.
    'N.B. sectors are mapped to blocks 1 to 1
      UART.str(string("hdskport_read"))
      crlf
      if hdsk_check_dts                                 'Check drive, track and sector are sane
        io_data := $FF                                  'Return error if not
        return
    #ifdef TriBladeProp
      r := tbp2.idle                                        'give up the bus
      CheckError(r)
      r := sd.initSDcard(spiDO,spiClk,spiDI,spiCS)          'init the SD
      CheckError(r)
      ' this method relies on the SD file using contiguous sectors !!! Only the first 128 bytes of 512 bytes used
    'RR20090818  sd_block := (drive_base[noparse][[/noparse]hdsk_drive+16]) + (hdsk_track * 32) + hdsk_sector
    'bug? only 8 floppies, the 4 hdisks
      uart.str(string("Read a sector"))
      crlf
    ' CheckError(err)
      r := sd.stopSDcard                                    'stop the SD (free up pins, but keep cog running)
      CheckError(r)
      r := tbp2.active                                      'activate the bus
      CheckError(r)
    and got this
    hdsk read
    00
    01
    00
    02
    06
    03
    00
    04
    39
    05
    F7
    06
    hdskport_read
    Read a sector
    And then it hangs. Ok, need to drill down into that subroutine and work out is it getting to the end, where it hangs etc...
    added more traces:
      crlf
      printhex(hdsk_drive)
      crlf
      printhex(hdsk_track)
      crlf
      printhex(hdsk_sector)
      crlf
      uart.str(string("Block read"))
      CheckError(err)
      uart.str(string(" Have read block"))
    hdsk read
    00
    01
    00
    02
    06
    03
    00
    04
    39
    05
    F7
    06
    hdskport_read
    Read a sector
    00
    06
    00
    Block read Have read block
    and then it hangs. Hmm, where does it go next?
    Post Edited (Dr_Acula) : 8/19/2009 12:28:46 PM GMT
    edited 2009-08-19 12:42
    James: suggest you try this - I can see when I read that I lock the sram out.
    '  UART.str(string("hdisk read "))
        return
    #ifdef TriBladeProp
      CheckError(r)
      CheckError(r)
    'bug? only 8 floppies, then 4 hdisks
    ' CheckError(err)
      CheckError(r)
      CheckError(r)
    #else
      sd_block := hdsk_base_block                       'Start at first block of first HD
      sd_block := sd_block + hdsk_drive * (32 * 2048)   'Skip on to the first block of the selected drive
      sd_block := sd_block + (hdsk_track * 32) + hdsk_sector 'Find correct block for the selected track/sector
      err := \disk.readblock(sd_block, @disk_buff )     'Read the block !
    #endif
      if err
        UART.str(string("Error hdisk read "))
        DisplayError(err)
        DisplayHDiskDTS
        io_data := $FF                                  'Return error code
      else
    #ifdef TriBladeProp
    ''    r := tbp2.active                                    'activate the bus
    ''    CheckError(r)
        'write the block out to sram
        r := tbp2.DoCmd("W", @disk_buff, hdsk_dma, 128)      'write to sram
        check_error(r)
    ''    r := tbp2.idle                                      'give up the bus
    ''    CheckError(r)
    #else
        BYTEMOVE (@ram_z80 + hdsk_dma, @disk_buff, 128) 'Virtual "DMA" the sector into DMA buffer address in Z80 RAM
    #endif
        io_data := $00                                  'Return OK.
      hdsk_last_command := hdskNull                     'Command completed
    PRI in_hdskport_write | r
    'Handle read from hdskport during a disk write command
        return
    #ifdef TriBladeProp
    '  err := $55                   '<== force a write error as no code yet
    '<==================need to fix this - it copied the data from sram to hub for writing to SD
    '???  BYTEMOVE (@disk_buff, @ram_z80 + hdsk_dma, 128)   'Virtual "DMA" the sector from DMA buffer address in Z80 RAM
      r := tbp2.DoCmd("R", @disk_buff, hdsk_dma, 128)      'read from sram (Virtual "DMA" the sector from DMA buffer)
      check_error(r)
      CheckError(r)
      CheckError(r)
      err := sd.writeSDCard(sd_block, @disk_buff, 128)  'write a sector
    ' CheckError(err)
      CheckError(r)
      CheckError(r)
    #else
      err := \disk.writeblock(sd_block, @disk_buff)     'Write the block!
    #endif
      if err
        UART.str(string("Error hdisk write "))
        DisplayError(err)
        DisplayHDiskDTS
      else
    postedit: added "| r" to PRI in_hdskport_write | r
    Post Edited (Cluso99) : 8/19/2009 12:49:15 PM GMT
    edited 2009-08-19 12:47
    Need a new debugging routine. Put it near the end:
    PUB PrintDec(value) | i
    '' Print a decimal number
      if value < 0
        -value
        uart.str(string("-"))
      i := 1_000_000_000
      repeat 10
        if value => i
          uart.tx(value / i + "0")
          value //= i
          result~~
        elseif result or i == 1
          uart.str(string("0"))
        i /= 10
    And now we should be able to get the sd block number:
      crlf
      printdec(hdsk_drive)
      crlf
      printdec(hdsk_track)
      crlf
      printdec(hdsk_sector)
      crlf
      printdec(drive_base[noparse][[/noparse]hdsk_drive+8])
      crlf
      printdec(sd_block)
      crlf
      crlf
      CheckError(err)
      uart.str(string("Have read block"))
    and (hopefully the maths is right), this returns
    hdskport_read
    Read a sector
    0
    6
    0
    789249
    789441
    Block read
    Have read block
    still hangs at that point. Next thing, is it returning E5?
    edited 2009-08-19 12:50
    Crossed threads - did you see above -think this may be it - fingers crossed
    edited 2009-08-19 12:56
    Hah, heaps of data and then an I>
    Ok, so it is these 4 lines that have been commented out
    '    CheckError(r)
        UART.str(string("Write to sram"))
        crlf
        check_error(r)
    '    CheckError(r)
    (ignore my write to sram message)
    ok, back to removing debug messages...
  • heaterheater Posts: 3,370
    edited 2009-08-19 13:01
    No, I'm pretty sure I'm not using 137 bytes for hard disks. Have a look in the mk_ziocog_img.py script that I used to make I:
    It's easy to read and you can see exactly how I transformed SIMH I: image into the ZiCog SD image.
    My I: disk may be starting to look different as I have deleted and written a few files to it. Sadly I can't access the actual file I use just now.
    You must have hard disk support compiled into the BIOS but if I remember correctly that is the default in the SIMH cpm2.dsk
    Also be sure you have a cpm2 from May or so. Peter Schorn fixed a bug for me in CBIOSX about then. Still that was to do with 8080/Z80 CPU detection so as long as you have CPU_Z80 set you should be fine.
    It might help to play with the SHOWSEC command in CP/M on TriBlade and compare with SIMH.
    I think Dr_A is right about what should happen with a HD full of E5. Check if it really works like that on SIMH.
    Got to go....
    CP/M knows about the hard disks geometry by asking the simulator, which provides the disk parameter table. We do this in zicog_demo.spin. look for "hdsk_dpb" and the routine "PRI in_hdskport_param".
    I suggest not changing those parameters just yet as we will then just confuse each other. Anyway CP/M 2 can only use 128 byte sectors. Also I'm not totally clear on how to change those tables it yet[noparse]:)[/noparse]
    A>i:
    I>dir
    No file
    I>stat
    A: R/W, Space: 512k
    I: R/W, Space: 8136k
    I>
    Now on to getting the writes working:
    A>pip i:mbasic.com=a:mbasic.com
    hdsk write
    Error hdisk write  ***Failed***
    D = 00 T = 0006 S = 00 DMA = F739
    Bdos Err On I: Bad Sector
    Post Edited (Dr_Acula) : 8/19/2009 1:06:18 PM GMT
    edited 2009-08-19 13:09
    Oops. I don't think the code has been written! See the last line
        return
    #ifdef TriBladeProp
    edited 2009-08-19 13:15
    see my post above for the write code. I also discovered the lines you commented out were the culprit. I was going to hit the sack but will wait up for this I have a feeling it is imminent smile.gif
    edited 2009-08-19 13:26
    Ah, you have the writes in there as well? Ok, off to code them.
    BTW heater, I went off on a tangent and used Cluso's vb6 program to make an 8mb binary file filled with E5. Dropped it into the simh and it all works. So that is a handy way to make blank disks.
    *note this is not on a triblade*
    A>i:
    I>dir
    I: MBASIC COM
    I>stat
    A: R/W, Space: 614k
    I: R/W, Space: 8112k
    I>mbasic
    BASIC-80 Rev. 5.21
    [noparse][[/noparse]CP/M Version]
    Copyright 1977-1981 (C) by Microsoft
    Created: 28-Jul-81
    32824 Bytes free
    Ok
    system
    I>
    edited 2009-08-19 13:31
    You Beauty!!
    Above works on the zicog too.
    Ok, tidying up a few things. brb
    Addit: back. Ok, comment out the hdsk read, and also the hdsk write messages
    Apart from that, exactly as your code was above. Time for a re-release? Or do we add drives J, K, L? Or are you going to sleep?!
      case io_data
        hdskRead:
          'UART.str(string("hdsk read"))
          'crlf
          hdsk_current_command := hdskRead
          hdsk_command_pos := 1
        hdskWrite:
          'UART.str(string("hdsk write"))
          'crlf
    and a printout:
    A>i:
    I>dir
    I: MBASIC   COM
    I>mbasic
    BASIC-80 Rev. 5.21
    Created: 28-Jul-81
    32824 Bytes free
    Ok
    print "hello"
    hello
    Ok
    system
    Unknown console status write with byte &H03
    Punch reset
    I>dirx
    Name    Ext Bytes   Name    Ext Bytes   Name    Ext Bytes   Name    Ext Bytes
    MBASIC  COM   24K
    1 File(s), occupying 24K of 8136K total capacity
    1023 directory entries and 8112K bytes remain on I:
    I>
    Post Edited (Dr_Acula) : 8/19/2009 1:39:29 PM GMT
    edited 2009-08-19 13:33
    Is it time for Yee Haa ! ?
    edited 2009-08-19 13:46
    I will just quickly tidy and post the code· do you still require the dec function? Anything else to add?
    edited 2009-08-19 13:47
    So close, yes.
    Uncommented the bootup for drives J, K, L
    Cloned drive I to the other three
    Then changed the <1 to <4 in this bit of code so it accepts 4 drives.
    PRI hdsk_check_dts : status
    'Check that selected hdsk drive, sector and track are within limits
      if (hdsk_drive < 4) and (hdsk_track =< 2048) and (hdsk_sector =< 128)
        status := $00
    Can now get into drive J as well. But getting bdos errors on drive K and L
    So close...
    Addit: given bdos errors seem more of a CP/M flavour than zicog (addit addit - yes bdos error on k:select means the drive doesn't exist according to cp/m), I tried attaching some more hard drives to the simh simulation. But no luck there, bdos errors as well, - maybe the syntax isn't right in that definition file.
    Post Edited (Dr_Acula) : 8/19/2009 1:56:56 PM GMT
    edited 2009-08-19 13:50
    Wow, sounds like ZiCog v0.11 is almost here.
    Actually I'm very tempted to give it v1.0. what do you think?
    Let me vanish for some hours first though.
    edited 2009-08-19 13:52
    Be sure your CBIOSX is compiled for 4 hard drives, I don't remember what the SIMH default is.
    edited 2009-08-19 13:56
    Ah, that sounds a clue heater. And mine is an old one, right?
    Probably need to bundle up a working simh group of dsk files?? ( I don't know how to recompile the CBIOSX)
    edited 2009-08-19 13:57
    Ha ha, I don't believe it. I just read the signon message for my version of CP/M:
    64K CP/M Version 2.2 (SIMH ALTAIR 8800, BIOS V1.25, 2 HD, 15-Jan-07)
    I wonder what "2 HD" means...
    And indeed, I can add two drives:
    d tracks[noparse][[/noparse]0-7] 254
    attach dsk cpm2.dsk
    attach dsk1 basic.dsk
    attach dsk2 games.dsk
    attach dsk3 sbasic.dsk
    attach dsk4 bdsc160.dsk
    attach dsk5 tools.dsk
    attach dsk6 wordstar.dsk
    attach hdsk1 i.dsk
    attach hdsk2 j.dsk
    set cpu 64k
    set cpu noitrap
    set cpu z80
    set cpu altairrom
    set cpu nonbanked
    reset cpu
    set sio ansi
    set sio nosleep
    boot dsk
    bye
    So just need to get the 4hd version.
    Post Edited (Dr_Acula) : 8/19/2009 2:04:13 PM GMT
    edited 2009-08-19 14:08
    Shouldn't the check for
    be
    if (hdsk_drive < 4) and (hdsk_track < 2048) and (hdsk_sector < 128)
    because 0...2047 and 0...127
    edited 2009-08-19 14:26
    Just to prove we are there·here is v102
    BTW the hd·L: has different hardware specs in the table
    We will now be able to setup an sram disk - what character drive ??? Its size will depend on cpm3 and banking.· "F" for fast ??? but we will have to change CPM won't we???
    I would like to get the sram done and the sd access before we go v1.0 please heater
    Post Edited (Cluso99) : 8/19/2009 2:41:22 PM GMT
    edited 2009-08-19 14:56
    Dr_A: Configuring and rebuilding CP/M under SIMH is easy peasy.
    There is a single submit file, SYSCPM2.SUB, to run that will assemble all the CP/M parts, do whatever it does with them and end up with the newly build CP/M on the boot sectors of A:
    So it's just:
    A>DO SYSCPM2
    Before that, change the configured number of hard drives by changing "nhdisks equ 1" to "nhdisks equ 4" in the config file CFGCCP.LIB.
    You get extra points if you can do this on the TriBlade rather than in SIMH. TriBlade should be able to rebuild itself now after all.
    edited 2009-08-19 15:02
    Clusso: RAM disk, yes.
    Some time ago I did make a modified CBIOSX that had a floppy disk definition customised for a RAM disk size.
    Can't remember what size we fixed on, but I don't think we took into account the requirements for banked memory.
    So how much banked memory are we needing?
    I don't know.
    edited 2009-08-19 22:19
    re Banked memory: I think we were aiming at using 256KB total. This would leave us 256KB + 512KB. So I guess for now we should make it 768KB. Perhaps I can do this (when I get hw) directly under CPM on the TriBlade under your instructions) - then I can change it later if need be (and document it from a novice point of view)?
    Guess I should get my SIMH working on the PC :-)
    Does this definition allow for 2 floppy sizes or would we be better simulating it as another small hard drive because it would be faster to do DMA style access withing the tb driver (say drive L: or can we skip drives and use R[noparse]:)[/noparse]?
    I need to look at dropping in the new fsrw but it will not be today :-(
    This is great progress after a break. Thanks·Dr_Acula and Heater ·jumpin.gifjumpin.gifjumpin.gifjumpin.gifjumpin.gif
    Just to answer the issue of 137 byte sectors on the floppies for SIMH (on the TriBlade thread). CPM does not verify those extra 3+6 bytes as I have disabled their "fixing" in my code, just do the 3 byte offset into the buffer. I have posted the files so you only have to concatenate them for your use, not remake them (if you like). I think we should post both the combined 1 file for all drives like you use and seperate files like I use. However, they will all use the first 128 bytes of the 512 byte sectors and all will be 32MB per disk, even for floppies (we just will not be using it). What I am doing makes it easy to refresh a drive and runs under FAT16. It still requires contiguous sectors within·each file (drive)·for direct access from the base. However, you cannot afford the hub space for the code, so your use of 1 contiguous file for all drives and no FAT16 makes complete sense.
    edited 2009-08-20 00:34
    All very exciting.
    Heater sent a PM overnght with a concept that avoids the need to run a vb6 program to make disk images. Some people may not have vb6. If the zicog boots up with a blank sd card, there may be enough space in the eeprom to get the bare minimum working to create a drive A on the sd card, write 32mb of e5 to it and then run xmodem. Then you can start transferring other files over, including programs to make all the drives (which are all the same anyway - just 32mb of E5). We use the same concept on the N8VEM and that has much more than enough space on a 32k eprom to get the bare mimimum working, eg CP/M and a couple of programs. The 'create a drive and format' program might only be 10 lines of spin. Open a file on fat16. Name it (based on a letter the user types eg B will create DRIVE__B.DSK. Write 32mb of E5 (hmm that might take a while. Faster sd card access??) Close the file. Enable that drive in the drive list array in spin.
    I've got something more complicated in mind involving networking. I've already got CP/M networked in the sense of having two boxes in different rooms and you run xmodem s on one and xmodem r on the other and they wirelessly transfer a file. But it isn't real networking as you have to set up xmodem on one machine and then go into the other room and set it up on the other.
    How would browsing a remote computer work? I think it needs two programs to run in parallel - CP/M, and a background program that serves up the files to the remote computer requesting them. That is multi tasking, and maybe MP/M can do that? You have one 'user' running CP/M, and another 'user' running a background program scanning a serial port/radio for input, and acting on it. I think it is possible but it needs multitasking. MP/M can multitask - I wonder if MP/M would run on the zicog? Can CP/M3 multitask?
    I guess back to the tasks at hand. What does banked memory do?
    Post Edited (Dr_Acula) : 8/20/2009 12:42:10 AM GMT
    edited 2009-08-20 08:50
    No need to make disk images - I posted zipped versions of them all a while back. Just not the hard drive because I didn't know what was required. It is relatively easy to get them onto the uSD from a PC with windows and an SD or USB converter. Probably could even do it with my printer which has an SD slot. One of my laptops has a builtin SD reader. It is also probably easier if we don't have everyone making their own files/drives.
    CPM3 runs but I had a keyboard glitch which you may have solved. Just change the #define and try (you need my drive files though which has a SIMH CPM3 drive already). IIRC I don't think CPM3 can multitask. MPM should most likely work. Unfortunately cannot get hardware till at least Tuesday when I am next in sunny and warm Qld.
    Once I get hardware I will get the fast fsrw for uSD running. It will be quite simple as lonesock builtin the requirement to release the DO pin by the SD card. Currently sdspiFemto has a patch which emits hundreds of clock cycles to force the card to release it. The code is way too complex for me to tinker with at the moment, and besides, lonesock and rokicki have done a great job with the new fsrw.
    Dr_Acula: If you get a chance tonight try CPM3 for me please. The keyboard input was missing every second character, so I needed to type it twice. If that works then maybe I can find out from Heater how to tell CPM3 it has banked memory and we can get it running smile.gif
    Banked memory is for CPM3 and has not been tested yet. The code is in place. IIRC it switches either 16KB or 48KB blocks into the 64KB window while the other 48KB or 16KB remains permanently in the 64KB window. Bank switching is done in the emulator code - no hardware!
    edited 2009-08-20 15:38
    Just got home from work. Midnight.
    Will get to cpm3.
    Created a new disk image in the simh for 4 hard drives ready for testing. New 'all' file. Note the 4 hard drives.
    attach dsk cpm2.dsk
    attach hdsk0 i.dsk
    attach hdsk1 j.dsk
    attach hdsk2 k.dsk
    attach hdsk3 l.dsk
    set cpu 64k
    set cpu noitrap
    set cpu z80
    set cpu altairrom
    set cpu nonbanked
    reset cpu
    set sio ansi
    set sio nosleep
    boot dsk
    bye
    Next, use R to read in SUPERSUB.COM.
    Use W to write CFGCCP.LIB out to the PC disk, and edit the line with the number of hard drives to 4.
    Use R to read it back in.
    run
    SUPERSUB SYSCPM2
    this recreates CP/M so it can handle 4 hard drives on the simh.
    Then on the propeller, tried recompiling itself with
    SUPERSUB SYSCPM2
    files exactly as they were on the simh.
    Took about 10 minutes, and it boots and it works, but all sorts of rubbish characters coming up.
    Then, tried copying the new disk image off the simh that works with 4 drives.
    Good news - it can read all 3 drives.
    Bad news - falls over on the 4th one, and I think this error is in cp/m??
    i:
    hdsk param
    Hdsk drive = 0
    hdskparam 0 = 20
    hdskparam 2 = 00
    hdskparam 4 = 05
    hdskparam 6 = 1F
    hdskparam 8 = 01
    hdskparam 10 = F9
    hdskparam 12 = 07
    hdskparam 14 = FF
    hdskparam 16 = 03
    hdskparam 18 = FF
    hdskparam 20 = 00
    hdskparam 22 = 00
    hdskparam 24 = 00
    hdskparam 26 = 06
    hdskparam 28 = 00
    hdskparam 30 = 00
    hdskparam 32 = 00
    hdskparam 34 = 80
    hdskparam 36 = 00
    I>j:
    hdsk param
    Hdsk drive = 1
    hdskparam 0 = 20
    hdskparam 2 = 00
    hdskparam 4 = 05
    hdskparam 6 = 1F
    hdskparam 8 = 01
    hdskparam 10 = F9
    hdskparam 12 = 07
    hdskparam 14 = FF
    hdskparam 16 = 03
    hdskparam 18 = FF
    hdskparam 20 = 00
    hdskparam 22 = 00
    hdskparam 24 = 00
    hdskparam 26 = 06
    hdskparam 28 = 00
    hdskparam 30 = 00
    hdskparam 32 = 00
    hdskparam 34 = 80
    hdskparam 36 = 00
    J>k:
    hdsk param
    Hdsk drive = 2
    hdskparam 0 = 20
    hdskparam 2 = 00
    hdskparam 4 = 05
    hdskparam 6 = 1F
    hdskparam 8 = 01
    hdskparam 10 = F9
    hdskparam 12 = 07
    hdskparam 14 = FF
    hdskparam 16 = 03
    hdskparam 18 = FF
    hdskparam 20 = 00
    hdskparam 22 = 00
    hdskparam 24 = 00
    hdskparam 26 = 06
    hdskparam 28 = 00
    hdskparam 30 = 00
    hdskparam 32 = 00
    hdskparam 34 = 80
    hdskparam 36 = 00
    K>l:
    hdsk param
    Hdsk drive = 3
    hdskparam 0 = 24
    hdskparam 2 = 00
    hdskparam 4 = 04
    hdskparam 6 = 0F
    hdskparam 8 = 00
    hdskparam 10 = 62
    hdskparam 12 = 01
    hdskparam 14 = 7E
    hdskparam 16 = 00
    hdskparam 18 = C0
    hdskparam 20 = 00
    hdskparam 22 = 20
    hdskparam 24 = 00
    hdskparam 26 = 02
    hdskparam 28 = 00
    hdskparam 30 = 02
    hdskparam 32 = 03
    hdskparam 34 = 80
    hdskparam 36 = 00
    Must be a hard disk.
    PC=F48C 09 AF=2442 BC=000A DE=F4D3 HL=F729 IX=0000 IY=0000 SP=E737
    and then hangs.
    So close. Just need to get drive L. Interestingly, that "must be a hard disk" error is not in spin so must be a cp/m error.
    Bizarre error now, supersub won't work and errors on line 0. ditto simh DO. So can't recompile any more on the simh.
    Might need to comment out the hdskparam comment eventually. Maybe the punch and console errors too.
    Post Edited (Dr_Acula) : 8/20/2009 3:48:43 PM GMT
    edited 2009-08-20 15:54
    I just happen to be looking at this. In zicog_demo.spin there are 4 hard parameter blocks dpb_0 to dpb_3 in a table labelled hdsk_dpb.
    These provide the disk geometry parameters to CBIOSX for the drive I: to L: respectively.
    Just happens that the last one, dpb_3, is different. It describes a "720K Super I/O Floppy" what ever that is/was.
    Suggest changing it to be the same as the other three and try again.
    edited 2009-08-20 16:13
    By the way I've always used "DO SYSCPM2".
    I don't know if that is the same a SUPERSUB or makes any difference.
