Newb assembly questions
Hello,
I'm trying to write some basic assembly. I need the program to test whether given pins are high·and·set a variable if they are.
This is what I've got so far:
I'm obvoiusly going wrong because it doesn't work.
I'm not sure how to get the pin mask to match ina and therefore test true, set wc and cause the loop to break. I'm also not sure how to only test the portion of ina relevant to the given pins. i.e. if there are inputs on other pins, not just 26,27,28 the mask will fail. How can·I test only 26,27,28 are high and ignore all other pins?
Some guidance would be greatly appreciated.
Many Thanks,
Dan
VAR
long cog
long pin1
long pin2
long pin3
long sig_detected 'is set to 1 if signal is found on all given pins
PUB main
dira[noparse][[/noparse]15]~~
dira[noparse][[/noparse]14]~~
start(28,27,26)
repeat
if sig_detected == 1
outa[noparse][[/noparse]15]~~
else
outa[noparse][[/noparse]14]~~
PUB start(p1,p2,p3) : okay
pin1 := |< p1
pin2 := |< p2
pin3 := |< p3
okay := cog := cognew(@entry, @pin1) + 1
PUB stop
if cog
cogstop(cog~ - 1)
DAT
entry
'Get pointer
mov p,par
'Move variables into cog memory
rdlong _pin1,p
add p,#4
rdlong _pin2,p
add p,#4
rdlong _pin3,p
add p,#4
'Set up pinmasks
mov _pinmask,_pin1
or _pinmask,_pin2
or _pinmask,_pin3
'Check pins
:loop mov temp,ina
'Test ina against pinmask
test temp,_pinmask wc ---This is probably where it goes wrong.
'Break if matched
if_c jmp #:break
jmp #:loop
'Write 1 to sig_detected
:break wrlong istrue,p
'Set up time
mov time,cnt
add time,delay
'Wait
waitcnt time,delay
jmp #:loop
delay long 40000
istrue long 1
' Uninitialized data
_pinmask res 1
_pin1 res 1
_pin2 res 1
_pin3 res 1
p res 1
time res 1
temp res 1
Many Thanks,
Dan
So, as long as your mask has a high bit for the pin in the right spot, then when you AND it with INA the rest of the numbers don't matter: your pin will be in !Z. Note that this only works for one pin at a time. I don't have any solutions for multiple pins beyond iterative testing.
And, if you haven't given it a shot yet, try PASD for assembly debugging.
Post Edited (SRLM) : 8/13/2009 10:00:43 PM GMT
:loop mov temp,ina 'Test ina against pinmask and temp,_pinmask 'mask the relevant bits cmp temp,_pinmask wz 'compare 'Break if matched if_z jmp #:break ...Andy
Thanks guys.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
So, an easier way would be
MOV wherever, #1 NR
to clear the Z flag and
MOV wherever, #0 NR
to set the Z flag
