New LCD board in development! - Page 2 — Parallax Forums
2»
  • Agent420Agent420 Posts: 439
    edited 2009-08-18 11:03
    Rayman said...
    I think displaying a high-color picture on the display will be a challenge for the Prop! I'm not really sure if this display actually has any GRAM... It may just be like a regular VGA monitor, with no memory. In that case, the TFT itself will hold an image for a while, but will need to be constantly updated...
    ^ I was thinking the same thing.
    Thanks for providing the datasheet.· My take is that it is a simple video display with no onboard ram, requiring a constant stream of video data to display an image.
    For most ucontroller projects, the 6 bit color is probably sufficient to make a great touch screen interface.
    I'm not certain that you could drive the display in full color without external ram...·I'm not certain an SD card could provide the data fast enough.· You'd need 391680 bytes for full 24bit color depth (480 x 272 x 3 bytes), and have to pass that 60 times a second; that's 23.5 MBs.
    edit -
    Tubular said...
    One thing that interests me about that display (and its 4.3" cousins) is that they don't specify a minimum dot clock.· I wonder if it therefore possible to assemble images on the fly (JPG decoding?) .· Or to send 1/8 of the screen, then pause and assemble the next 1/8, send the next 1/8 etc..
    ·You know, I'm not sure if the display is 'static'...· That's a damn good question.
    Post Edited (Agent420) : 8/18/2009 11:38:12 AM GMT
  • AleAle Posts: 2,363
    edited 2009-08-18 11:31
    You have to provide 60 fps. These displays have no built-in memory. Each image is 128K for 8bpp.
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
  • RaymanRayman Posts: 15,748
    edited 2009-08-18 12:42
    Well, I'll find out tomorrow maybe!
    I'm going to start by trying a very slow SPIN driver and see if it will work at all...
    It is a little strange that the datasheet doesn't give a minimum dot clock...
    If it does need 60 Hz, my fallback plan is to modify the VGA driver to drive the display. Perhaps even allowing simultaneous VGA and LCD display...
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
  • blittledblittled Posts: 683
    edited 2009-08-18 16:11
    I would definitely be interested in a used touchscreen. Will you be selling the Accessory board for the PSM at the Expo? How much is the Accessory board? ·Thanks!
    What electronics need - MORE POWER!!!!!!!
    Post Edited (blittled) : 8/18/2009 4:21:40 PM GMT
    edited 2009-08-18 20:29
    Sorry, I won't have more accessory boards ready for the expo... The excitement over this new display caused a bit of delay on that front...
    I'll have to double check, but I think I only have the "like new" displays at the moment...· But, I'm expecting the "slightly used" ones in the near future...
    edited 2009-08-21 16:39
    It works!!!
    I'm able to turn the backlight on, change the color on the display and can read from the touchscreen!
    A lot of work to do though...
    But, I'm very happy because now I have something new to talk about at the expo!
  • hover1hover1 Posts: 1,929
    edited 2009-08-21 20:34
    Good Deal Ray!
    I hope someone will record the talk at the Expo.
    Jim
    Rayman said...
    It works!!!
    edited 2009-08-22 18:54
    Just sold a few bare LCDs at the Expo!
    Here's the Digikey part number for the connector I'm using: 609-3439-1-ND
