MOV or RDLONG
I am trying to understand the difference.
Are these the same?
MOV temp1, accel
RDLONG Temp1, accel
accel RES 1 'local to asm, Why are not local variables specified as long, word, byte etc. I assume you ONLY have longs in ASM.
So far I think that for Longs set in the Main program (the caller of the ASM method), you would pass the address of the long in main
to the method with a parameter. Then if that variable needs to be accessed, you RDLONG the pointer to acceess the 'outside world'. But if you are working with local
declared variables in the ASM object/method, you just mov them.
Post Edited (TChapman) : 8/17/2009 5:15:10 PM GMT
Are these the same?
MOV temp1, accel
RDLONG Temp1, accel
RDLONG moves a 32-bit word from a hub memory location to a cog memory location. The source operand value specifies the hub address. In your case, "RDLONG temp,accel" takes the hub address contained in cog location "accel" and uses that to read a 32-bit long from hub memory into cog location "temp".
In ASM there are only 32-bit memory locations. You can pack 16-bit words and 8-bit bytes into these locations using the assembler, but there are no instructions to directly manipulate them. It's all 32-bit values.
A real world scenario, are these the same?
PUB moveX motorr(0, @X, @Xcurrent, 1, 0, @Xdone) PUB motorr( ipinstart, ipos, icurrent, iforward, ireverse, iID ) [noparse][[/noparse] ... ] newposition := ipos currentposition := icurrent return COGNEW( @cogstart, @ipinstart ) DAT ORG 0 cogstart JMP #cogstart0 pinstart LONG 0 ' input parameters radr LONG 0 forward LONG 0 reverse LONG 0 ID LONG 0 cogstart0 [noparse][[/noparse] ... ] skipping code repeat1 'if LONG[noparse][[/noparse]newposition] < LONG[noparse][[/noparse]currentposition] RDLONG ctmp1, newposition MOV ctmp2, currentposition RDLONG ctmp2, ctmp2 CMPS ctmp1, ctmp2 WC 'if newpos < current, set C flag to 1 IF_C JMP #endif2 'jmp to #endif2 (if c flag is 1) MOV rep3cnt, C1000 'versus repeat1 CMPS newposition, currentposition WC 'if newpos < current, set C flag to 1 IF_C JMP #endif2 ' jmp to #endif2 (if c flag is 1) ctmp1 RES 1 ' PASM variables ctmp2 RES 1 run RES 1Post Edited (TChapman) : 8/17/2009 5:49:36 PM GMT
RDLONG ctmp2, ctmp2
CMPS ctmp1, ctmp2
Why don't you just write
RDLONG ctmp2, currentposition
CMPS ctmp1, ctmp2
Also this statement:
Will compare only the pointer locations and not the values from Hub memory.
RDLONG temp1, pointer1 'get the values into local vars
RDLONG temp2, pointer2 'get the values
CMPS temp1, temp2 compare
