New LCD board in development!
I hope to have a prototype ready for the Expo next week!
Here are·a·few features:
4.3" TFT LCD display with 480x272xRGB resolution.
·-·display has an integrated touch screen!
·- backlight and microreflective technology make it ideal for both indoor and outdoor·use
Full-size SD card with WP and CD feature
Stereo audio output with headphone amplifier
Keyboard and Mouse via dual USB-A connector
VGA connector
TV connector
mini-USB for·programming and/or power·
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Post Edited (Rayman) : 8/14/2009 12:36:33 PM GMT
VGA connector
TV connector
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
If it's not Parallax then don't even bother.
I have changed my avatar so that I will no longer be confused with others who use generic avatars (and I'm more of a Prop head then a BS2 nut, anyway)
Also, it's amazing how you can purchase some older (but new) GPS products that include a similar screen, probably based on an entire linux system,·for not much more!· (make a good hacking project)
PG
How did you connected it ? are you using an external RAM as framebuffer or limiting the number of colors ?
Btw, we want pictures ! (I want pictures).
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
I may reconsider this in the future, maybe using 2 Props to give better color.
The plan is to try to do simultaneous LCD and VGA output using the same 6 color pins and 2 sync pins. We'll see if that works!
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
PG
That GPS unit does look like a nice hacking project!
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Do you think you'd be interested in buying just the bare LCD?· I think I could provide these for a very low cost from my supplier...
--Steve
1986 Chevy EL Camino·· No prop yet
1984 Suzukie GS1100GK No prop yet
The LCDs I have has been restored to "like new" condition, and have been sold as "new", but have had their touchscreens replaced...
But, I can also get some that are direct pulls from returned to the factory units. Those would be much cheaper, but might have a smudge/scratch or two on the screen...
Anybody interesting "used" displays? Or, do you only want "new" ones?
I'll post a datasheet soon.· First, I have to remove some vendor specific info...
Post Edited (Rayman) : 8/16/2009 7:15:10 PM GMT
This unit needs a couple extra chips, but I'm leaning toward leaving off the DAC, ADC, and accelerometer. So, I think the price may only be $30 or so more than the PSM...
How does that sound?
I think it is the one I get around here (Germania). The price is good, it is around 21 Euronen plus shipping.
I was thinking on a CPLD with 2 128k SRAMs to drive it. Of course with less colors, say 4bpp, it can be used with the propeller. But I think that if more COGS are sync'd and with an external RAM and two latches It could be used in 8 or 16bpp, what are your thoughts ?
I appreciate that to drive RGB would require 3x8 pins .
is it feasable to to 8 bit latches, then only 8 pins for the data total proably 12 or so would be required
check this schematic for a similar method.
maybe it would need the LCD controller ILI9325
I bought a couple of the breakout boards, and drive them from a PIC
http://www.thaieasyelec.net/index.php/display-module/breakout-board/breakout-board-2-8-inch-qvga-tft-lcd-with-touch-screen/p_3.html
http://www.mcudevzone.com/archives/Manual/ELT240320TP_BB(NEW).pdf
Also, there is only one 60-pin FPC cable for all the connections...
Agent420:· Here's the datasheet [noparse]:)[/noparse]
I'll bring some "as new" LCDs too, just in case anybody wants to buy some....
That will give you a day and a half or so...
I am looking forward to seeing your display and board in Demo mode.
See you Saturday
Roger
I'd really be interested in a device that provided this high rez LCD with a touch screen, SD (or uSD) card for image storage. A simple two way protocol using serial that I could call up images from the SD card and have them displayed on the LCD and have some way for touch screen feedback.
This would allow for a 2nd prop (or·any uController)·do driving this device and acting as a HMI.
I'm thinking something very similar to your PSM's serial interface. I'd like to be able to tweak the protocol so I can add/modify to the base functions.
With the SD card for image storage you could have fancy buttons and menus popup. Even splash screens. Way cool.
Jim Fouch
FOUCH SOFTWARE
Still, I suppose you could just read the image from SD over and over again and show it... But, a better scheme would be to use external RAM for Prop.
But, then you really get into pin count issues!
Note that you can still show a quasi-decent image with just 6-bits. I did it already with the Prop·using 3 synced VGA drivers!
One thing that interests me about that display (and its 4.3" cousins) is that they don't specify a minimum dot clock.· I wonder if it therefore possible to assemble images on the fly (JPG decoding?) .· Or to send 1/8 of the screen, then pause and assemble the next 1/8, send the next 1/8 etc...
Nice having just the 1 connector too.·
tubular
