PINK Server and Port Forwarding
xanatos
I am attempting to access my PINK server module from "the world at large" and I have (apparently) enabled port forwarding on my router/modem (Westell 327W), but the ports when scanned all say "closed".· The IP address in the PINK is set as static (192.168.1.44) and works well when viewed from inside my network.· I have enabled port forwarding on two ports (7788 and 591 for both UDP and TCP).· Nuttin'!!!· I go to my (checked immediately before testing) IP address, add the : and the port number (such as :7788 or :591) and - only get the "page cannot be found" or some such 404-ish screen.· Going to whatsmyip.org and using their port scanners shows the ports are closed - but the other ports around them show timeout, so there's something different there....
Is there some oddity or trick I am unaware of to get these visible outside the firewall from remote locations?
Thanks very much!
Dave X
Thanks very much!
Dave X
Although you forwarded those ports, the default port for web page access will be port 80 if not blocked for incoming traffic by your ISP. You will need to forward that port to the PINK module. Also, for the other port to work with your UDP you need to set that port in the PINK Module as the UDP Port.
Chris Savage
Parallax Engineering
Thnaks for the info,
Dave
Chris Savage
Thanks again, and let me know if you have any sudden flashes of insight!
Dave
Chris Savage
Port forwarding usually only makes sense if you have fixed IP addresses assigned by your ISP. I wonder if you have dynamic ports?
Unfortunately some ISP's do block inbound port 80 requests because that's the usual port a web server listens to for http client connections. In other words, the ISP doesn't want you to run web servers -usually because they themselves provide hosting services they want you to pay for. (<rant> The BIG providers also ANNOYINGLY randomly change ports for email - wrecks havoc for many of my clients. :-( --- the ISP's claim they do this to reduce spam, but I think it's not true. </rant>)
That said, it is also quite normal these days to request static IP addresses on your account so that you can run servers, virtual networks, internet phone equipment - and PINK servers. Of course, you usually have to *pay* to get those IPs. They literally get you coming and going.
However, a high(er) speed, small business, broadband connection often comes with X number of fixed IPs gratis. You often have to request to have them enabled. For example, where I'm posting from right now is across a DSL connection at a modest 3Mbit down, 140-168? kbit up. I get 8 usable fixed IPs. Costs about $60/month.
So clearly you might not have to convince your client to switch but perhaps upgrade.
cheers,
- Howard
I'm working on a small routine that will submit an HTTP GET request to a script on my website's server, which will then record the IP address coming in, into another file so that when I goto a special page on my website, it will redirect me to the current IP address and the PINK Server. My IP is dynamic, but is changes fairly infrequently (usually only when I reboot my router for some reason, like messing with port forwarding settings, etc). This will work if I can get the PINK to be seen through the router, so that's the first priority. If I can do that, my system should take care of all issues arising from dynamic IPs. I Hope.
Chris - as of the moment (last night, actually, I've been making PC boards all day today) I have NO traffic able to pass through the router to the PINK. Hopefully I will be able to start messing around on that end of things Saturday or Sunday. By then I'll be ready to do something that doesn't involve developer, etchant or drill presses! ...can't wait to farm that particular aspect of the contract out to a board house!...
Dave
sounds like a router setting.
- H
Chris Savage
