New LCD board in development! — Parallax Forums
RaymanRayman Posts: 15,748
edited 2009-08-22 18:54 in Propeller 1
I hope to have a prototype ready for the Expo next week!
Here are·a·few features:
4.3" TFT LCD display with 480x272xRGB resolution.
·-·display has an integrated touch screen!
·- backlight and microreflective technology make it ideal for both indoor and outdoor·use
Full-size SD card with WP and CD feature
Stereo audio output with headphone amplifier
Keyboard and Mouse via dual USB-A connector
VGA connector
TV connector
mini-USB for·programming and/or power·
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Post Edited (Rayman) : 8/14/2009 12:36:33 PM GMT
    edited 2009-08-14 14:58
    I'll be at the Expo, looking forward to seeing it! Would you accept some componants as trade for one? smile.gif (if you are planning on selling it)
    Computers are microcontrolled.
    Robots are microcontrolled.
    I am microcontrolled.
    But you·can·call me micro.
    If it's not Parallax then don't even bother.
    I have changed my avatar so that I will no longer be confused with others who use generic avatars (and I'm more of a Prop head then a BS2 nut, anyway)
  • Agent420Agent420 Posts: 439
    edited 2009-08-14 15:04
    That does sound quite interesting.· I wonder if that is similar to the PSP lcd that SparkFun carries?
    Also, it's amazing how you can purchase some older (but new) GPS products that include a similar screen, probably based on an entire linux system,·for not much more!· (make a good hacking project)
  • P!-RoP!-Ro Posts: 1,189
    edited 2009-08-14 15:13
    I find this to be very interesting as well, and I already have a perfect project idea for it. When you do get the final version, I will buy one from you. I might even buy more farther in the future, as well.
    PG
  • AleAle Posts: 2,363
    edited 2009-08-14 15:19
    There are a number of sources for such a display. What everyone wants to know is:
    How did you connected it ? are you using an external RAM as framebuffer or limiting the number of colors ?
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
  • RaymanRayman Posts: 15,748
    edited 2009-08-14 15:38
    This display only operates in RGB mode, so I'd need all the Prop's pins to do 24-bit color. So instead, I'm using just 6-bit color, basically turning the display into a Prop VGA monitor...
    I may reconsider this in the future, maybe using 2 Props to give better color.
    The plan is to try to do simultaneous LCD and VGA output using the same 6 color pins and 2 sync pins. We'll see if that works!
    edited 2009-08-14 15:49
    BTW: I have access to a large supply of these displays at very low cost... So, I have a feeling that people might be interested in a more low cost board for this display... I'm interested in any ideas or suggestions!
    edited 2009-08-14 16:03
    Sounds very nice... I have two such 4.3" displays sitting next to me waiting for me to make an SMD breakout board for the fine pitch connectors...
    Rayman said...
    Here are a few features:
    - display has an integrated touch screen!
    - backlight and microreflective technology make it ideal for both indoor and outdoor use
    VGA connector
    TV connector
    mini-USB for programming and/or power
    Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
    Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
    www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
    Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
    edited 2009-08-14 16:38
    It sounds like your intention is for it to be a stand alone unit. For me, I would prefer it to have better color and be configured by another micro. If you should descide to give it a second prop though, I would stand by it as functionality is one of the primary things I'm looking for.
    PG
    edited 2009-08-14 18:03
    You could make it a slave device and have a 2nd Propeller run it through serial commands.
    edited 2009-08-14 23:36
    Agent420 said...
    It is very similar to the PSP LCD, but not the same, and a lot cheaper!
    That GPS unit does look like a nice hacking project!
  • jazzedjazzed Posts: 11,803
    edited 2009-08-15 00:41
    Hey Rayman, sounds exciting. Low cost is always attractive here [noparse]:)[/noparse] I may have a keyboard/LCD game chassis waiting for one of these. What is the outer width & length of the LCD?
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
    edited 2009-08-15 01:12
    The LCD is about 4-1/8 X 2-5/8.· Actually, the diagonal looks to be about 4.5", so I have to double check now why I'm calling it 4.3"...
    Do you think you'd be interested in buying just the bare LCD?· I think I could provide these for a very low cost from my supplier...
    edited 2009-08-15 01:22
    Maybe 4.3 is the viewing area diagonal. I might be interested in the bare LCD. Send me a specification link.
    --Steve
  • Cole LoganCole Logan Posts: 196
    edited 2009-08-15 02:43
    I'd be interested in this. Or at the very least the screen by it self
    1986 Chevy EL Camino·· No prop yet
    1984 Suzukie GS1100GK No prop yet
    edited 2009-08-15 13:37
    Rayman said...
    I'd be interested in some details.· PM if you'd like.
    edited 2009-08-15 14:37
    Will this be cheaper then the PSM?
    edited 2009-08-16 18:55
    Question:
    The LCDs I have has been restored to "like new" condition, and have been sold as "new", but have had their touchscreens replaced...
    But, I can also get some that are direct pulls from returned to the factory units. Those would be much cheaper, but might have a smudge/scratch or two on the screen...
    Anybody interesting "used" displays? Or, do you only want "new" ones?
    I'll post a datasheet soon.· First, I have to remove some vendor specific info...
    Post Edited (Rayman) : 8/16/2009 7:15:10 PM GMT
    edited 2009-08-16 19:11
    Microcontrolled: It's hard for me to say right now what the price will be. First, I have to get the thing to work!
    This unit needs a couple extra chips, but I'm leaning toward leaving off the DAC, ADC, and accelerometer. So, I think the price may only be $30 or so more than the PSM...
    edited 2009-08-16 20:06
    How much can you get the used screens in for? Is there an "easy" way to interface them with the Prop?
    edited 2009-08-17 10:18
    The cheaper the better, provided they are functional.· I don't mind a smudge here or there so long as they are readable.
    edited 2009-08-17 13:19
    I think I can sell the "used" displays for $15 and the "like new" ones for $30.·
    How does that sound?
    edited 2009-08-17 13:29
    That sounds great to me.· Any chance of the tech docs you alluded to earlier so we can better understand what is required to interface them?
    edited 2009-08-17 14:56
    Rayman which display are you getting ? this one ? www.sharpsma.com/Page.aspx/americas/en/part/LQ043T3DX02/
    I think it is the one I get around here (Germania). The price is good, it is around 21 Euronen plus shipping.
    I was thinking on a CPLD with 2 128k SRAMs to drive it. Of course with less colors, say 4bpp, it can be used with the propeller. But I think that if more COGS are sync'd and with an external RAM and two latches It could be used in 8 or 16bpp, what are your thoughts ?
  • mikestefoymikestefoy Posts: 84
    edited 2009-08-17 15:03
    I would be interested in this LCD with a prop.
    I appreciate that to drive RGB would require 3x8 pins .
    is it feasable to to 8 bit latches, then only 8 pins for the data total proably 12 or so would be required
    check this schematic for a similar method.
    maybe it would need the LCD controller ILI9325
    I bought a couple of the breakout boards, and drive them from a PIC
    http://www.thaieasyelec.net/index.php/display-module/breakout-board/breakout-board-2-8-inch-qvga-tft-lcd-with-touch-screen/p_3.html
    http://www.mcudevzone.com/archives/Manual/ELT240320TP_BB(NEW).pdf
    edited 2009-08-17 15:06
    Ale:· This display is very similar to that one, but not the same...· I don't see the word "reflective" in that one so it may not be as good outside...
    Also, there is only one 60-pin FPC cable for all the connections...
    Agent420:· Here's the datasheet [noparse]:)[/noparse]
    edited 2009-08-17 15:20
    My prototype PCBs come Wednesday... Hopefully, I'll have it working for the Expo on Saturday!
    I'll bring some "as new" LCDs too, just in case anybody wants to buy some....
  • Roger LeeRoger Lee Posts: 339
    edited 2009-08-17 17:39
    Rayman said...
    That will give you a day and a half or so...
    I am looking forward to seeing your display and board in Demo mode.
    See you Saturday
    Roger
  • Jim FouchJim Fouch Posts: 395
    edited 2009-08-17 19:07
    Raymond,
    I'd really be interested in a device that provided this high rez LCD with a touch screen, SD (or uSD) card for image storage. A simple two way protocol using serial that I could call up images from the SD card and have them displayed on the LCD and have some way for touch screen feedback.
    This would allow for a 2nd prop (or·any uController)·do driving this device and acting as a HMI.
    I'm thinking something very similar to your PSM's serial interface. I'd like to be able to tweak the protocol so I can add/modify to the base functions.
    With the SD card for image storage you could have fancy buttons and menus popup. Even splash screens. Way cool.
    Jim Fouch
    FOUCH SOFTWARE
    edited 2009-08-18 10:10
    I think displaying a high-color picture on the display will be a challenge for the Prop! I'm not really sure if this display actually has any GRAM... It may just be like a regular VGA monitor, with no memory. In that case, the TFT itself will hold an image for a while, but will need to be constantly updated...
    Still, I suppose you could just read the image from SD over and over again and show it... But, a better scheme would be to use external RAM for Prop.
    But, then you really get into pin count issues!
    Note that you can still show a quasi-decent image with just 6-bits. I did it already with the Prop·using 3 synced VGA drivers!
  • TubularTubular Posts: 4,745
    edited 2009-08-18 11:01
    Rayman, thanks for posting the datasheet.
    One thing that interests me about that display (and its 4.3" cousins) is that they don't specify a minimum dot clock.· I wonder if it therefore possible to assemble images on the fly (JPG decoding?) .· Or to send 1/8 of the screen, then pause and assemble the next 1/8, send the next 1/8 etc...
    Nice having just the 1 connector too.·
    tubular
