X-Racer questions...
Well, I now have my DIY HYDRA!· I just need to get another eeprom and the blank HYDRA cards/all the other goodies...·
I was playing X-Racer on my DIY HYDRA (or DRAGOON as it has now been christened) and I was struck by a sudden inspiration: what if I could make it more along the lines of MarioKart64, where there is a mini-map, your current place (i.e.; 1st, 2nd, etc up to 8th) and have a better main menu or rather, an actual main menu.
Since I have been using the prop·since March of this year, I'm not too experienced in actual hard long work and coding.·
· I did, however, find out how to run the HYDRA games on a dev tool like the demo board/Gadget Gangster Propeller Dev Kit...· Anyways, the code is the same as the JTC_XRacer_010 except I have the xinfreq to 5_000_000, doubled the pll, and changed the tv pins in the tv_params section·to %001_0101 so it has a basepin of 12.
So, is it possible to modify this so it has a main menu, minimap, only 8 other cars (which would go a LOT faster than they normally do so as to make it a fun and challenging game) and a placement system?· I'm not asking for code, just whether it is possible, and any help you can provide.·
Thanks.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
· I did, however, find out how to run the HYDRA games on a dev tool like the demo board/Gadget Gangster Propeller Dev Kit...· Anyways, the code is the same as the JTC_XRacer_010 except I have the xinfreq to 5_000_000, doubled the pll, and changed the tv pins in the tv_params section·to %001_0101 so it has a basepin of 12.So, is it possible to modify this so it has a main menu, minimap, only 8 other cars (which would go a LOT faster than they normally do so as to make it a fun and challenging game) and a placement system?· I'm not asking for code, just whether it is possible, and any help you can provide.·
Thanks.
Thanks.
The computer cars are handled the same way. A car is randomly placed in memory, and if it goes outside the limits (of either too far ahead or a little bit behind), a new car is randomly placed. This could also be handled in a similar way where you have computer cars traveling at a constant around the track. But as the game is setup right now, there can only be one computer car on the screen at one time.
