Digitial Audio
A friend of mine at work is searching for an answer on digital (optical) audio signals. I am not sure of his end goals but his interest is to be able to change the volume level of the output using the original source.
Basically, if using a device with digital audio output, he wants to be able to turn up the volume on the output device to increase the volume; not the amplifier receiving the digital signal.
Is there a protocol that encodes a bit pattern to instruct output volume levels for audio?
I haven't seen this ability on anything I have used but I know this is the right place to find out.
As for increasing the volume, just like any digital value there are limits to how far the signal can be increased before it maxes out.·
I guess I should try and explain a little better.
The question is whether there is a way to instruct the receiver to increase its output volume. He wants to know if this can be done over the digital signal. No need to increase the digital levels, just send a data stream to instruct the end unit to raise the volume.
Rick
Failing that, you could always motorize the volume knob (really) ;-)
In some cases the output of a D/A can be changed by changing the reference voltage to it, but the range is limited.
The digital information going to the D/A can also be multiplied to vary levels, but again the range is limited.
Some devices use a digital pot between the output from the D/A (or preamp) and the amplifier to vary the level.
None of these methods would be easy to hack or control with an add on circuit.
With a bit more detail on the specific device and what he wants to accomplish he may get a better answer.
