Illuminator-CA and Sparkler - Propeller controlled LEDs!
I have created another device that can control LEDs (or motors or relays etc). The device is called the Illuminator-CA. There are 24 outputs via MOSFETs that will operate in PWM or BAM. The outputs are arranged in groups of three for a total of 8 groups. Each group is well suited to control common anode wired RGB LEDs.
The Illuminator-CA has a Propeller controlling everything. There are a couple of LEDs and a button for user interface as well as DMX512-A/RS-485 circuitry. The device will be configured through a serial terminal. At the moment I am verifying hardware and working through firmware. The next step is to then post it on the Brilldea web site. Drop me a PM if you are interested in learning more as I am selling beta units.
I also created the Sparkler, which is a grouping of 24 RGB LEDs on a rigid PCB. The Sparkler can be mated to the backside of the Illuminator-CA or attached via wires. The Sparkler has the 24 RGB LEDs arranged in eight groups, or you can alternately solder the jumper pads on the back of the Sparkler to combine groups - in other words instead of 24 I/Os needed, you could combine them so only 3 I/Os control the entire block.
I'll keep the thread updated and post more details as I verify the design.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
www.tdswieter.com
Searider
Shawn Lowe
When all else fails.....procrastinate!
Great job! You have a flair for style that really shows in your boards.
The first pass at the firmware uses Beau's PWM object. I want to create a BAM object - or maybe there is one already, I haven't checked.
www.tdswieter.com
One of the key design elements for the Illuminator-CA was that everything had to be pluggable. I recently worked with some devices that had to have every terminal block undone and other oddities. I decided things must be easy to hook-up and easy to plug/unplug. This helps for home and commercial installation during install and commissioning.
www.tdswieter.com
What does the " CA " in Illuminator-CA stand for?
Roger
www.tdswieter.com
I'm still in my blinking light phase, can't have too many LEDs.
I'm more comfortable with common cathode when I have a choice.
Roger
Common anode versus common cathode is a bit of a sore spot with me. I haven't learned yet the appropriate chinese terms for it, so when I am in the markets I try to explain what I want or ask a question on a product. I have bought products of both types and usually it is when I want one or the other. I prefer common anode from an easy to control standpoint such as n-channel MOSFETs, but I can understand the argument for safety with common cathode.
www.tdswieter.com
www.tdswieter.com
