Accuracy of DS1302
I use the RTC with the recommended 32kHz, 6pF·crystal bought from Parallax. The crystal is soldered to the legs on the RTC and then bended over the top of it. The two·legs of the·RTC is then cut·so they don't go through the·PC board.
The RTC was syncronized with a radio clock on August 1. Yesterday the RTC-time was 38 seconds ahead of the time recieved by the radio clock.· 38 second too fast by 11 days. Is this an error I should expect of·a RTC like this or is it really bad?
See this datasheet: www.vishay.com/docs/35043/xt38t.pdf
Post Edited (Mike Green) : 8/12/2009 4:02:00 PM GMT
according to their data sheet.
Being off by 38 seconds in 11 days is about 40 ppm, so your crystal
seems to be off by more than the data sheet states, assuming that
the temperature stayed reasonably constant.
20 seconds error in 11 days would be 20 ppm.
phil
Post Edited (phil kenny) : 8/12/2009 4:02:34 PM GMT
But·it means I have to adjust the clock every third week or so because·I really need·this RTC to be as accurate as possibly, though one minute error or so is acceptable.
My radio clock I mention above gets its signal from the DCF77, a time transmitter located in Frankfurt, Germany some 1500 km away. The time·information is transmitted by binary signals on 77.5 kHz, more on Wikipedia:
http://en.wikipedia.org/wiki/DCF77
Now I wonder.. does it exist any kind of RTC that is made to receive this signals [noparse][[/noparse]from DCF77] and also is easy to interface with the BS? Or, will a BS of any kind be able to handle such signals if connected to a 77.5 kHz receiver and then be able to adjust the RTC itself? Maybe·eliminate the need of the whole RTC and just·depend on the received signals?
Any ideas, you smart people out there?
Look through these: para.maxim-ic.com/en/results.mvp?fam=osc_mod&285=32.768kHz&980=TCXO
Thanks again Mike!
This subject comes up pretty frequently actually. I wish Maxim would publish more information in the datasheet for the DS1302 so customers would understand why this happens. The typical issue with the clock accuracy is that the clock is running fast, as is the case here. This is usually caused by improper mounting of the crystal in the system. There are very specific PCB layout requirements in place to ensure best crystal accuracy. When these aren’t followed, that accuracy goes right out the window. According to the engineers at Maxim/Dallas, when the crystal is not shielded from stray noise (following previously mentioned guidelines) it is possible for the oscillator circuit to occasionally get an extra pulse here and there. This adds clock cycles causing the clock to run fast over time. Mounting the crystal on top of the IC may be great for prototyping, but it adversely affects the overall accuracy.
I am linking the AppNote which discusses the various reasons for clock accuracy issues. Starting on Page 3 under Crystals and Accuracy and continuing on through page 5 it discusses everything from improper crystal load tuning to RFI interference, etc. I hope this helps. Take care.
http://pdfserv.maxim-ic.com/en/an/AN504.pdf
Chris Savage
Parallax Engineering
A big factor is the parabolic temperature coefficient of the 32kHz xtal. Without compensation the xtal slow down as the temperature moves much above an below the turn point, around 25 degrees C. Watches don't drift too much when worn on a wrist, because the body is a constant temperature oven. For extended temperature operation with better precision, there are real time clocks like the Dallas DS3232 and the DS32C35, which have the txco (temperature compensated crystal oscillator) built into the package A similar clock from Intersil is the ISL12020M, and from Microcrystal (division of Swatch) is the RV-3029-C2. I reproduce the temperature compensation graph from the latter, because it shows nicely the effect of compensation compared to the natural parabolic curve of the crystal.
Tracy Allen
www.emesystems.com
