Powering the Demo Board off of USB Power during debugging — Parallax Forums
WBA ConsultingWBA Consulting Posts: 2,938
edited 2009-08-13 00:10 in Propeller 1
Is anyone aware of any concerns I should have if I modify the Propeller Demo Board to make use of the 5 volts present on the USB bus? I would like to be able to run programs during debugging without worrying about external power. My plan was to run a jumper from USB5V over to a 2 pin header that is attached to the demo board's 5V bus. If I attach a jumper shunt on the header, that would bridge USB 5V over to the Prop's power.
Since a USB port can deliver 500mA (per spec) and can be paired with a second port to provide 1A, the supply should run the demo board nicely. I am not sure if the FTDI chip will advise windows of it's power needs and have windows limit the current on the port it is attached to.
Also, the Power Supply Chart on the website doesn't list any recommendations for the Prop. This may be due to the fact that the prop is so versatile, the range of current needed is heavily dependent on your program/design?
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
Post Edited (WBA Consulting) : 8/12/2009 9:34:58 PM GMT
