Two Devices Share Serial Lines
I am currently communicating to my Prop using a FT232RL.· I also have a XBee module that I have been playing around with last week.· My end application requires the exact same data to be available over the FT232RL or the XBee.· Is it possible to use the same TX/RX lines for both the FT232RL and XBee?
Ryan
Ryan
I used the 150-ohm resistors between the FT232RL and prop, and then 1k resistors between prop and my XBee.· I am not sure if 1k is appropriate, but at 57600 baud, everything seems happy.
