SX Emulator for Propeller
Bean
This is just the beginning of my SX Emulator for the Propeller.
Could some of you Propeller Gurus look and see if I'm doing anything stupid so far ?
Keep in mind this is just the beginning framework for the emulator.
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
Bean.
Yes it does...
I've just opened up " Ubicom SX Family User’s Manual"
It says an opcode is only 12 bits. e.g. "JMP addr9" is "101k kkkk kkkk".
So fetching instructions with just a read word does not seem quite right. Or are you planning on "stretching" the ops.
Using words and ignoring the upper four bits makes a lot of sense.
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+ Advanced dual Propeller SBC with XMM and 256 Color VGA - PCB, kit, A&T available NOW!
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
First, I would use PC directly - I would re-write the interpreter loop as:
I just shaved three instructions off for you!
Right now I'm not too worried about speed or doing anything "clever". I'm just trying to get something going.
Bean.
Yes it does...
It does make sense to get it running first...
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
