Keyboards... USB keyboards connecting to PS2 on the prop
It was my impression that the newer USB·keyboards did not contain the smarts to also connect as a PS2 keyboard.
Well, I just connected a recent (1-2 year old???) HP keyboard via the USB to PS2 adapter and it works.
So, it is definately worth trying if you don't have a PS2 keyboard :-)
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
Which USB to PS/2 adapter are you using?
Brandon C.
No purchase necessary. See back panel for more details.
Tired of the same old robot brains? not enough processing power? Get the Propeller Robot Module now!!
P.S. - No PS/2 adapter needed if you have a spare usb cable/plug lying round (dont forget the pullup resistors!)
Quicker answers in the #propeller chat channel on freenode.net. Don't know squat about IRC? Download Pigin! So easy a caveman could do it...
http://folding.stanford.edu/ - Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
I think it works the other way round with the BIOS as the BIOS has to have some basic USB keyboard support to handle *any* USB keyboard, not that it talks to the USB keyboard as PS/2 before boot. But not all USB keyboards are legacy compatible, in fact I think and have found that most aren't. The ones that come with an PS/2 "adaptor" plug are designed with the PS/2 interface on the keyboard and autodetect which interface is being used. The adaptor is a simple passive "gender-bender" type of affair and plays no part in what the keyboard does. After all the keyboard still only uses two signal connections, for PS/2 thats the clock and data, and for USB it's the D+ and D-.
*Peter*
I'm sorry, but this is wrong.
A USB keyboard has two modes :
A) A simplified USB mode for use in "legacy BIOS" applications, where a HID enumerator is not present.
Any ability to interface using a PS/2 interface is in addition to these USB modes and usually activated by some form of biasing on the data lines. It is simply not possible for a USB port to talk to a keyboard in PS2 mode.
I've got 2 keyboards here that are USB only, but most of mine will do USB or PS/2 with the right adapter. The adapter is a hardware device with no smarts. It simply changes the pin routing. I suspect the keyboard detects either USB or PS/2 by looking at the voltages on the signal lines when it powers up.
lt's not particularly silly, is it?
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
1) Most PS/2 devices are also USB so it gets rid of that awkward "adaptor"
2) Leaves the way open for future software to be incorporated that will handle the device in native USB mode
Another reason is that the USB socket is cheap and easier to obtain and cables also are a dime-a-dozen (almost). There is also no reason why this same socket can't be used for external I2C as well, why not, it's up to software anyway.
*Peter*
I think actually that your original statement was just plain wrong. It's not about not being able to explain ideas perfectly, you have a gaming keyboard that works and then you assumed that all keyboards must be the same and then assumed that's how the BIOS manages to talk to them at pre-boot, then stated these assumptions as facts.
Nobody is worried about this assumption though as the matter has been clarified for the sake of the other forum members who might have acted on what you said. If you had said XYZ USB keyboard WILL interface to PS/2 then that would not have been misleading.
But it's cleared up now, and I didn't know that about the "simple USB mode" prior to enumeration which Brad kindly pointed out, so it's all an education!
*Peter*
Peter:· I'm thinking you just connect the PS/2 data ports to D+ and D- and give +5V and GND on the other two pins...· Is that all there is too it?
USB
1 +5V
2 D- PS2DAT
3 D+ PS2CLK
4 GND
*Peter*
I had a tidy up at work last week, and chucked a load of single and stacked USB conns away. Some even had integrated magnetics for the RJ45.
As they say " Chuck it away and you will need it tomorrow"
Style and grace : Nil point
But a stacked connector is probably USB though. Anyway, USB connectors are cheap and even the corner shop sells them (yeah, buy a $5 hub and rip out 4 connectors)
*Peter*
The stacks I had were mostly either 2 USBs or 2 USBs and a RJ45. The latter would have been ok for the Ybox2.
Over here the Pound shops do 4 port hubs
Now, back to siesta.
Post Edited (Toby Seckshund) : 8/10/2009 2:56:20 PM GMT
