FullDuplexSerial with 8N1? *SOLVED*
Hi!
Don't tell me, that it's OK to transmit 2 stop-bits if only one is required. I know that. But this is a slight speed-penality (10%).
FDS does transmit 2 stop-bits. See scope shot. The deltaT (bottom of screen) of 0.053ms is quite 1 / 19200.
I tried to reduce that to one but failed.
It's more than just changing the 'mov txbits, #11' to 'mov txbits, #10'
Seems ... ah well ... I shut up.
It's not a speed problem with SPIN, the buffer is well filled and tx-speed was 19200 Baud. Nothing that would be "fast".
Its the same with 115200 Baud, but there I see jitter in the pause between characters. Not the topic.
Could someone point me to how to fix that in FDS, please?
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Post Edited (Nick Mueller) : 8/9/2009 10:57:59 AM GMT
Nick
YADRO
*Peter*
I got it, code looks like this now:
the 'or txdata, #1' has to be removed.
Code checked with some text, $FF, $00, $AA, $55. All transmit fine, no bit lost ...
Nick
PS: Quite a cool gadged, such a protocol-analizer.
YADRO
