Help getting mini sd card to work
I'm having some trouble with the sd card. I ran sdrw test on the prop and I got the message "mounting. Returned from start -13." Also, when I ran this code:
·text.str(STRING("Starting Up",13))
··· i:=sd.mount(0)
· if (i<>0)
··· text.str(STRING("error",13))
··· repeat
· text.str(STRING("SD Card Mounted",13))
It would just freeze on the text "starting up." Is there something wrong with it? What should I do?
Also--I'm using a 4gb sdhc and the propmod-us_ps_sd. The fsrw program version is 1.6.
PG
··· i:=sd.mount(0)
· if (i<>0)
··· repeat
PG
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
PG
PG
Alternatively, just use the two files I'm attaching to this post! [noparse][[/noparse]8^)
We're working on a release, but both Tom and I are a little busy. Sorry about the wait.
Jonathan
lonesock
Piranha are people too.
PG
PG
PG
PG
num := 5
i:=sd.pwrite(@num, 1)
if (i<>0)
term.str(string("busted", 13))
repeat
it gave me the message busted tho and i dnt know why
PG
try
num := 5
i:=sd.pputc(num)
if (i<>0)
repeat
also are you mounting the disc and saving the file?
PG
PG
sd.mount(0)
sd.pclose
commands
PG
to the point--I think I'm getting a hang of things a little here, with putc placing one variable and getc retrieving it when the pointer is located on the spot, but how can I move that pointer? For instance, say the number saved is 1234. is there a way to move the pointer over 3 so when i use getc i get the number 3?
PG
PG
PG
PG
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
If it's not Parallax then don't even bother. :-)
I have changed my avatar so that I will no longer be confused with others who use genaric avatars.
Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order.
Cheap·shipping unless specified!··········150 left!!··
As one other code example, here is the link to a simple serial terminal app, showing off multiple file access and things like that. Hopefully it is of some use.
fsrw.hg.sourceforge.net/hgweb/fsrw/raw-file/caa4f46fdf89/serial_terminal.spin
Check out the execute_command routine. It has examples for file copying and reading the directory, etc.
Good luck on your project!
Jonathan
lonesock
@jon--i've been going through that code trying to understand it, but it's probably gunna take a lot of coffee to stay focussed
PG
sd.pread( @numret, 4)
I'm only getting one number back which is 5, and I'm supposed to get 56. what am I doing wrong here?
PG
I tried changing byte to long and I got
100992516
PG
