Basic stamp alarm clock project - finished item video
Hi
Just thought I would post the link to a video of the alarm clock I made using a Basic stamp using a BS2P-40.
It has the DS1302 time keeping chip, and 5x Max7219 display drivers (one for date, current time, alarm time, countdown and keypad leds).
Built using bits found in the shed. The only bought parts were the IC's, Led digits and the buttons.
The rest is MDF, spare offcuts of aluminium from B&Q etc
Sound is a combination of a couple of old ISD2560 soundboards I had which I used for the phrases and a Wooloworths £5 MP3 player stores the 15 explosion/alarm effects.
Driven through a 30W amp to a 10" bass speaker and tweeter.
Base holds a 3.5A 12v PSU (which I found at a car boot sale). Needs some serious cooling however - you can hear the fan. Adds to the effect I reckon.
The MP3 player turned out to be a pain in the backside to use.
Track one on the MP3 had to be a blank track, as the player starts the second you power it up. Then the stamp (controlling the play/pause and FF buttons) pauses the mp3 player and simply skips forward to the required track depending on what has been set by the user.
Another issue the MP3 player had is it goes to sleep after 2 minutes, so I pulsed the 'repeat' button on the player with a 555 timer and that keeps it awake all the time.
Next time... I will just buy another sound board!
Heres the video:
Yay!... another pointless project to clutter up the house!
Steve
Post Edited (Steve2381) : 8/3/2009 11:10:22 AM GMT
Heres the video:
Steve
That is ...well...ummmm.......what's the word...oh......yeah...............INSANE!
Do u make props for movies?
"THE ONLY TRUE WISDOM IS IN KNOWING YOU KNOW NOTHING." - SOCRATES
My official guess is that you post a bunch of insanely cool stuff like this on youtube and end up getting noticed [noparse];)[/noparse]
You may know how to make a nuke, but your undoing is showing everybody your access code. Now the question is, which one of us will sneak into your house tonight, enter the code, and take the whole world out?·
[noparse]:)[/noparse]
One suggestion: Don't use it as a travel alarm, especially if you're flying.
Yes, its amazing how careful you have to be when you have an alarm clock like this. I took it over to my brothers house and felt slightly uneasy carrying it - under a blanket!
I am just waiting for the surveillance team to move in opposite me and the phones to be tapped.
It might be another pointless project to clutter up the house But ..........>>>>
This is the·COOLEST PROJECT I have seen That is·not useful in any way·but to·have a lot of fun with
·I am sure that you learn a lot from do this Project
I thought it was very funny to watch all thing that you having it do
··Thanks for any·
Sam
SO, you planning to release schematics / source code / internal photos etc for the Completed Projects section any time soon..?
Vern
You know what its like, you start something, it evolves.... and gets totally impractical.... oh, is that just me?
I only tinker with it when I get an evening spare, and I started it a couple of years ago. Now, I would have a much easier time building it as this is the total limit of the basic stamp... you really cannot cram any more programming into the slots available (although my programming is FAR from tidy). Now I would use a different starting platform.
Technology has advanced and now you can get simple RS232 driven MP3 players etc. But, I was pretty determined not to spend a fortune on it and just build it with 'Smile' from the workshop - hence the cheap £5 MP3 player that drives the main SFX.
Like I said, there are still some bits to finish, like a keypad remote control, and a cradle so that it stands nicely. If I get the time, I would like to make a proper fibreglass missile enclosure for it to go inside that opens and reveals the missile.
Still makes me laugh now when I power it up.
Girlfriend just thinks I am mad...
You set the alarm time, and then if you set the fader, the blue lights stop and the digits fade to level 1 after a minute. Then you lie in bed.... watching..... watching.... only 6 hours, 34 minutes and 23 seconds until I have to get up......22 21 20 19
My favourite awaking sound on it is the music track 'The world is no enough' by Garbage. It starts on the lowest volume and plays all the way through getting louder until at the very end of the track you get the light (2000 watts of halogen + strobes) and explosion effect. By then, you should have disarmed it.
Its a SLIGHTLY more subtle way of waking up than the straight explosion.
As for a schematic... OH MY GOD, where would I start! I might try to put together the basic layout if I get an evening free.
Hang on... there's men at the front door with guns.....
Post Edited (Steve2381) : 8/4/2009 11:04:16 AM GMT
Shawn Lowe
When all else fails.....procrastinate!
Started off oh so neat, and then as space got tighter.... and tighter....
Going to be even more compact now, as I am fitting the RF remote control tonight which allow me to operate it remotely.
I'm away from work till wednesday but can get you the information then, what part of the UK are you from?
Has duplicate authorisation key and a fairly decent range.
Based on a couple of BS1's and a 418Mhz transmitter and receiver pair. Pretty simple really.
The push buttons on the front of the Nuke send a unique code to the main stamp via a diode matrix and using 5 stamp input pins. So I just got the receiver BS1 to decode the same codes from the transmitter, which sends the data via 8 bits of information using SEROUT.
First bit is a synch signal, then the next 5 are the push button inputs - again via a diode matrix in the remote and finally the switch state of the Auth and Arm switches.
The transmitter only sends a SEROUT with the button data if you press a button on the remote, or change the state of one of the latched switches. That way it doesn't always transmit and flatten the battery. Yes the stamp is still running awaiting a keypress, but anything helps!
Right, really must do something more constructive!
Hey just studying your photo of the main core...
I can see on the right hand side of the photo... the back side of a stripboard.
What type of tool do you use to cut the strips with?
I have been using stripboard for prototyping and have had trouble doing a clean job of cutting the strip circles?
any info is appreciated.
Keep up the good work.
Thanks, Dwight
Mike2545
This message sent to you on 100% recycled electrons.
