PWM control of unipolar stepper motor?
I want to control a stepper motor that's rated at 3.6V @ 200mA using a ULN2803A.· However, I only have a 24V supply voltage.· Can I just drive each coil at 15% duty cycle PWM instead of using a different power supply or a power wasting resistor?· The parallax propeller makes this much easier than other chips.
If I have 4 pins then I would:
-PWM 15% pin 1, all other pins 0% pwm
-delay 1ms
-PWM 15% pin 2, all other pins 0% pwm
-delay 1ms
-PWM 15% pin 3, all other pins 0% pwm
-delay 1ms
-PWM 15% pin 4, all other pins 0% pwm
-delay 1ms
repeat
Correct?
-delay 1ms
-delay 1ms
-delay 1ms
-delay 1ms
repeat
Correct?
The old teleprinters coils would pull over at 12v but to get operating speed 80+ volts through a resistor was used.
Style and grace : Nil point
