Ultra Minimum Propeller - Fact or Fiction?
As understood, the absolute minimum setup for experimentation:
- Propeller chip
- PropPlug
What is the speed and max program size that can be run?
Other ideas and applications?
Post Edited (humanoido) : 8/3/2009 9:11:23 AM GMT
- Propeller chip
- PropPlug
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
- RCFAST == ~12Mhz
- 32k just the same as with the eeprom.
Both of your questions are answered within 8 lines of the picture you included on page 17-18 of the Propeller manual.
lt's not particularly silly, is it?
*Peter*
*Peter*
Having built a number of PIC programming circuits that did not work reliably that was a big win immediately for the Prop for me, before I was even aware of it's other unique features.
Since you are probably thinking about hooking up a bunch of Props, the only drawback that I see, is that you have to program each Prop chip individually. So, that forces you to have an EEPROM for each chip, program it once, and load it too the EEPROM. It would be nice if the Prop had a 20 MHz internal oscillator, and maybe 32 KB of flash RAM. But, what do I know.
As for programs, I did not run into any problems, as long as you stayed under the 32 KB limit, but I only did some very minimal stuff.
Ray
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
If you want to stack a bunch of these together
assuming that the bottom Propeller has a crystal (don't cut off any pins though).
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Added: On second thought, with a shared clock configuration, it might be possible to download them all with RX connected on each, but TX connected only on one Propeller.
--Steve
Post Edited (jazzed) : 8/3/2009 3:59:27 PM GMT
I asked about this two weeks ago- curious what the bare minimum was to get up and running on a breadboard. I got my DIP Propellers today. 5 minutes of tinkering later and I had a ready to use Propeller dev setup.
The only real deviation is that I'm using a crystal. No reason not to use one. Without one, you'll be running at a really low speed, possibly with timing/reliability issues on top of it. If cost is *that* much of an issue, you'd be better off with a $2 PIC18 or mid-range AVR. Heck, you could get a lower-end PIC32 and a crystal for less than $5. For a high-performance and higher priced controller like the Propeller it's hard to argue that it's worth the $0.10 - $0.15 you'd save per crystal (in bulk) to cripple an $8 MCU into $1 performance. Net loss of $6.80. :P
Don't get me wrong- I'm all for trying things just because. I'd be happy to try it without the crystal if anyone is curious. In lieu of a PropPlug I used a Arduino- both the Arduino and the PropPlug use the FTDI FT232RL chip to do USB to TTL. Handy for the regulated power, too. [noparse]:)[/noparse]
Post Edited (RevAaron) : 8/4/2009 4:36:22 AM GMT
Wow..
What a neat way for an Ardunio user to get started with the Propeller!
Would you mind documenting those connections you are making for me? (I'm not an Arduino guy)
OBC
New to the Propeller?
I would make sure to connect all the Vss and Vdd pins. I recall reading some older posts that mentioned it wasn't a good idea to use only one of each, leaving the others disconnected. It only adds a couple more wires or traces to make that happen.
Robert
They certainly are on all the boards I have here. Bad things can happen if they are not.
if using a module like mine it is not usually esential to connect all because the pcb is good conductor but still best if you can.
If you keep the propeller on all the time, then the code will have been loaded into RAM by the prop-tool, so there wouldn't be a need for EEPROM. Otherwise, if the power cycles, yes, an EEPROM would be needed to store the code.
--Steve
I've been curious about clocking multiple props off one crystal...
Steve you said earlier here that N props would need a more robust clock.
Do you guys know the correct circuit to use one crystal to drive say 8 or 12 props? Would simple line driver/buffers be enough, or are there frequency stability issues? (I'm a crystal N00B [noparse]:)[/noparse]
thanks
- H
PS. Humanoido - you always seem to spark interesting discussions [noparse]:)[/noparse]
For running multiple Props from a common clock, you will need either an external oscillator or a master Prop which provides a clock signal from one of its port pins to all the others' XI pins.
